Forum Home › Forums › Understanding the Software › Convert historical data from V5 to V6
- This topic has 19 replies, 2 voices, and was last updated 11 months, 2 weeks ago by
March 25, 2024 at 9:08 am #14271
kcks66
ParticipantHi Mikhail,
Currently I am in the works to migrate Rapid SCADA from v5.8.4 to v6.2.0. I had done manual configure all channels in v6, right now is the time to migrate historical data from v5 to v6.
I downloaded from your utilities tools-v6 HistConv5to6_dotnet8 and extracted. I double click the HistConv5to6 application file somehow looks like a command prompt window pop up then automatic close down.
Pls advice for the steps. Thank you.
March 25, 2024 at 11:05 am #14275
You should run
cmdfirst. Then execute the *.exe in the command prompt.March 26, 2024 at 11:55 am #14280kcks66
I got the converter to run. However, I got many errors. The converter stop when encountered error. I need to remove those error .dat files and re-run the converter.
Is there a way to make the converter automatically re-run by skipping errors .dat files?
By the way, why there is some error from v5 .dat file?
Pls advice and thank you.March 27, 2024 at 12:39 pm #14291
It is important to find the cause of the error. May be those files contains correct and useful data. Could you open the problem files in the Administrator app to view data and try to realize why they can cause the error?March 27, 2024 at 1:23 pm #14292kcks66
I can see the error .dat file contain two data per one minute, if compared to other success .dat file contain one data per minute:
Any .dat file with more than 1440 will be treated as error.
March 28, 2024 at 10:47 am #14299March 29, 2024 at 7:35 am #14301kcks66
I can see the new converter can continue to run after encountered those data more than 1440 per day.
March 29, 2024 at 7:53 am #14302kcks66
Previous Rapid SCADA v5 I use .dat as my main achieve. Right now after I migrated to v6 I want to use ModArcPostgreSql as my main achieve.
Those .dat files from v5 I used the converter to convert to v6 .dat files format, can be trend by modArcBasic only, right?
Pls advice for what should I do after I set ModArcPostgreSql as my main achieve and still can trend back those converted historical data previously from v5?
This reply was modified 2 years, 8 months ago by
kcks66.
March 29, 2024 at 10:59 am #14304
Yes.> what should I do after I set ModArcPostgreSql as my main achieve and still can trend back those converted historical data previously from v5?
Using Chart Pro, you can create a chart profile to open data from *.dat archive. Reports also support choosing an archive.
However, may be in your case it is better to use PostgreSQL as a secondary archive.March 29, 2024 at 1:12 pm #14306kcks66
I would like to explore all of these advice.
1) How shall I configure the chart profile to open data from *.dat archive?
2) Am I need to enable/true the below?
<!– User can select archive –>
<SelectArchive>false</SelectArchive>3) I need to active both set of Achieve like below?
April 1, 2024 at 10:05 am #14310
1) Create a copy of ChartPro.xml, for example, PlgChartPro_Profile2.xml
Add a new line into ChartPro_Config.xml<Profile fileName="PlgChartPro_Profile2.xml">Profile 2</Profile>
April 1, 2024 at 10:06 am #14311
MikhailModerator2) In Elastic Report, use SelectArchive and/or DefaultArchive
3) Yes. Activate archives that are in use.
April 2, 2024 at 2:27 am #14314kcks66
Thanks. I tried all of them and they worked accordingly.
After I discussed and showed to the system users, we finally decided to use PostgreSql as only one achieve as main achieve.
My next step is to migrate all the *.dat files (in v6 format already) into Postgresql database. Pls advice any faster or easier way to do such migration?
April 2, 2024 at 12:03 pm #14317
It’s up to you. However, why don’t you use *.dat format as a secondary to make the system more reliable?April 2, 2024 at 12:07 pm #14318
MikhailModerator> migrate all the *.dat files (in v6 format already) into Postgresql database
Currently, there is no ready to use converter. 2 approaches come to my mind:
1. We can develop a converter by a contract.
2. Deploy an additional instance of Rapid SCADA and use Rapid Gate module to transfer data from the additional instance to the main instance of Rapid SCADA. -
