Forum Home › Forums › Understanding the Software › Scheme copy
- This topic has 30 replies, 3 voices, and was last updated 4 years, 10 months ago by
August 5, 2021 at 2:23 pm #9354
MikhailModeratorAnother method:
Hold the Ctrl button and click the components to multiple select.
Press Ctrl+C to copy components to the clipboard.
Then choose Edit – Paste Special to paste components.Scheme Templates also good, but using many frames may affect performance.
August 6, 2021 at 2:07 am #9355lilytech
ParticipantI install the Extra Component Cheme. It has Frame now.
I make a new sch file, put several Frames on it.
I have a device file, file name is one-device.sch
How to set Url for these Frames?
(note: setting of “../Scheme/Scheme. aspx?viewId=35” does not work).
August 6, 2021 at 2:33 am #9356lilytech
Participantcopy paste works, thank you.
the problem:
if I have 128 devices.
if I need to edit one, all 127 left devices need edit.so I still hope to try frame method.
August 6, 2021 at 2:54 am #9357lilytech
ParticipantThe Gauge in Extra components does not work.
Should I make payment to make it work?
If yes, how to make payment? How to get computer code?
August 6, 2021 at 6:00 am #9359
manjey73Participant(note: setting of “../Scheme/Scheme. aspx?viewId=35” does not work).
In order for the link to work, you need to add this scheme to the views, give it rights, configure the display as a separate view, then you will know its ID, then you insert this view into another scheme with this link. The ID number will be the one that you will be assigned by the system. To hide this view from the list in the tree, you need to set the”Hide” checkbox
You will still have to create 128 views and hide them, and specify them for frames
August 6, 2021 at 6:02 am #9360
manjey73ParticipantYou can get a temporary computer code for testing, and you need to pay for the code that will work in the WEB, if you have a separate server, Web server
August 6, 2021 at 6:48 am #9361lilytech
ParticipantI try Extra Gauge 1st.
In a new sch, I only put a gauge, set the Data->input channel.
In main menu->plugs->installed: the “Extra scheme components” are active.
Localhost/scada test result shows:
At Views->new.sch, it shows:
“Registration failed for “Extra Scheme Components”.”
“No library found for component extra:Gauge”.What is the problem?
August 6, 2021 at 8:24 am #9362
manjey73ParticipantOverload the server and also make the Ctrl+F5 command in the browser to update.
After you have entered the registration key, you need to download the data from the server, and then upload it back to the server.This should be described in the documentation.
This reply was modified 4 years, 10 months ago by
manjey73.
August 6, 2021 at 9:15 am #9364lilytech
ParticipantDuring installation for extra components, I have not meet “registration key”.
Where to get it?And where is the document link for extra components?
August 6, 2021 at 9:33 am #9365
manjey73ParticipantInstallation of Webstation Plugins
7. Download data from the server
August 6, 2021 at 9:37 am #9366
manjey73Participant
But as mentioned above, the page loading will be long, it is still better to make copies of the elements and change the channels. A bit not for such things inserting a schema into another schema
August 6, 2021 at 5:15 pm #9370
MikhailModeratorDuring installation for extra components, I have not meet “registration key”.
Where to get it?After activating the plugin, look in Main Menu – Registration in Webstation
August 7, 2021 at 2:44 am #9373lilytech
Participantall are ok now.
August 7, 2021 at 2:48 am #9374lilytech
Participantexcept the content in the frame can not be loaded even for long long time.
August 7, 2021 at 2:55 am #9375lilytech
ParticipantWe will waiting for your next version to try.
