Map Plugin question
Forum Home › Forums › Understanding the Software › Map Plugin question
Viewing 4 posts - 16 through 19 (of 19 total)
  • #17088
    itconsult
    Hello
    I checked PlgMap.xml location and it’s OK. It is in Instances – Default – Webstation – Configuration. Webstation version is 6.2.1.0 and PlgMap version is 6.1.1.0. You can see all in this print screen:
    https://jumpshare.com/share/TJ5xyNLkq9iA3DOQX1Ef
    #17098
    Thank you for the screenshot.
    I suppose, it’s needed to upgrade ScadaWeb to version 6.2.2.0.
    The currently used versions of the plugin and the web app use the different APIs.
    #17099
    More info here.
    #17100
    itconsult
    Hello Mikhail
    Thank you for your support. I installed new version and it worked
