How to use ModArcPostgreSql?
Forum Home › Forums › Understanding the Software › How to use ModArcPostgreSql?
Viewing 7 posts - 16 through 22 (of 22 total)
  • #14084
    kcks66
    Hi Mikhail,
    I installed v6 in a different PC this round and tried to use PostgreSql as my main achieve again.
    However I am facing error in this PC, error log as below:
    https://ibb.co/cXJh9yS
    FYI, this PC is administrator password protected.
    Pls advice and thank you.
    #14085
    kcks66
    Hi Mikhail,
    My mistake; I thought Rapid SCADA will automatically create the rapid_scada database in PostgreSQL.
    I manually create the rapid_scada database and everything works as expected.
    #14086
    Yes, the rapid_scada database should be created manually.
    Thank you for the update.
    #14087
    Try the new module ModDiffCalculator. The configuration example is included in the archive. The module is compatible with Rapid SCADA 6.2.x. In case of questions, create a new topic.
    #16308
    kcks66
    Hi Mikhail,
    I want to ask what is the function of Pull to period as below:
    https://ibb.co/nN27xFmV
    I want to ask what is the function of Use in-memory cache with cache size ratio as below:
    https://ibb.co/ZRFyw8M3
    #16310
    For example, you set it to 10 seconds. If a timestamp of the point is 10:59:51, it will be changed to 11:00:00.
    Caching will be useful when data from multiple devices arrive at the same time stamp. This usually happens when a new hour begins. In this case, the channel values ​​for this time stamp, which are necessary for calculations using formulas, will be read from the DB only once. If the project has many thousands of channels with formulas, the difference in data processing speed will be significant.
    A driver should support reading archives from your devices.
    #16318
    kcks66
    Hi Mikhail,
    Thanks for your explanations.
