Elastic Report Flexibility
Forum Home › Forums › Understanding the Software › Elastic Report Flexibility
Viewing 15 posts - 16 through 30 (of 30 total)
  • #7687
    dinop
    So far I made this. But I want to get a report based on shifts. Can you explain me how to set reading hour from 0:00 to 8:00, from 8:00 to 16:00 and from 16:00 to 0:00.
    Example:
    <Section>
    <SectionOptions>
    <ID>Section3</ID>
    <SectionType>DataData</SectionType>
    <Subheading>Consumption by sfifts</Subheading>
    <SubheadingVisible>true</SubheadingVisible>
    </SectionOptions>
    <Table>
    <ColumnGroup name=”Consumption”>
    <Column name=”Radna” />
    <Column name=”Jalova” />
    <Column name=”Prividna” />
    </ColumnGroup>
    <RowGroup name=”Shifts” calcTotal=”true” calcAvg=”true”>
    <Row name=”1.Shift (0:00-8:00)” rowStyle=”row-lg”>
    <Cell cnlNum=”104″ calcType=”Val”/>
    <Cell cnlNum=”105″ calcType=”Val”/>
    <Cell cnlNum=”106″ calcType=”Val”/>
    </Row>
    <Row name=”2.Shift (8:00-16:00)” calcType=”Val” calcTotal=”true” calcAvg=”true” rowStyle=”row-lg”>
    <Cell cnlNum=”107″ calcType=”Val” />
    <Cell cnlNum=”108″ calcType=”Val” />
    <Cell cnlNum=”109″ calcType=”Val” />
    </Row>
    <Row name=”3.Shift (16:00-0:00)” calcType=”Val” calcTotal=”true” calcAvg=”true” rowStyle=”row-lg”>
    <Cell cnlNum=”110″ calcType=”Val” />
    <Cell cnlNum=”111″ calcType=”Val” />
    <Cell cnlNum=”112″ calcType=”Val” />
    </Row>
    </RowGroup>
    </Table>
    </Section>
    Picture:
    https://ibb.co/2dTzBWV
    #7693
    Now I understand what do you need to show in the report.
    Elastic Report doesn’t directly cover this case.
    May be you could print all values from 0:00 to 23:00, and then use Excel formulas (that can be inserted in the report) to calculate the required values.
    #7697
    dinop
    Can you provide an example of how to do it?
    #7700
    The default report example contains Excel formulas that refer other cells:
    <Field calcType="Formula" value="=R[-5]C-R[-5]C[1]" cellStyle="cell-tot" />
    Alternatively, you could try to develop formulas that calculates the required values for the input channels. And then use the result in the report.
    #7701
    If you need to realize Excel formulas syntax, you should enter a formula in Excel and save the workbook as XML Table 2003.
    #12882
    manyan2028
    hello Mikhail, I receive you reply about the ElasticReport, press the F12, I get the follow infomation.
    Failed to load resource:the Server Responded with a status of 404(not found)。the file report-args.min.css , report-args.js connot found in my PC。
    #12891
    Did you copy that files when installed the plugin?
    #12910
    manyan2028
    Hello, the ElasticReport File donnot contain the above Files. can you privide the new Link to me。thanks
    #12912
    You should download the plugin for proper version of Rapid SCADA.
    #12916
    manyan2028
    https://rapidscada.org/download-all-files/download-elastic-report-plugin/
    I downLoad the file from the Above link。But it doesnot contain the files:report-args.min.css , report-args.js.
    #12918
    Right, there are 2 links: the plugins for Rapid SCADA 5 and Rapid SCADA 6.
    Which one do you use?
    #12919
    That’s true, the reuired files are missing in the archive.
    It will be fixed the next week. Please wait for an update.
    Thank you for reporting the issue.
    #12920
    manyan2028
    I want to use the RapidScada 6 ,thanks。
    #12921
    I will post the update in this topic.
    #12952
    Elastic Report was fixed and uploaded to the website. To use it, you should upgrade Rapid SCADA to 6.1.3.
