Data Exporting
Forum Home › Forums › Understanding the Software › Data Exporting
Viewing 11 posts - 16 through 26 (of 26 total)
  • #13696
    If the module is active, check it log files.
    #13718
    KeanoC
    Here are my logs after making the connection but i dont seem to be getting any data automatically exporting to my db.
    2023-11-28 08:11:09 [B100][B100$][ACT] Server 6.1.1.1 started
    2023-11-28 08:11:09 [B100][B100$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll
    2023-11-28 08:11:09 [B100][B100$][ACT] Start logic processing
    2023-11-28 08:11:09 [B100][B100$][ACT] The configuration database has been read successfully
    2023-11-28 08:11:09 [B100][B100$][INF] Number of active channels for archiving: 335
    2023-11-28 08:11:09 [B100][B100$][INF] Number of active channels for sending commands: 0
    2023-11-28 08:11:09 [B100][B100$][ACT] Compile the source code of scripts and formulas
    2023-11-28 08:11:09 [B100][B100$][ACT] Added the following dependencies:
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\netstandard.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.ComponentModel.Primitives.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Console.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Diagnostics.Process.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Linq.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Private.CoreLib.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Runtime.dll
    C:\Program Files\SCADA\ScadaServer\ScadaCommon.dll
    C:\Program Files\SCADA\ScadaServer\ScadaServerEngine.dll
    2023-11-28 08:11:10 [B100][B100$][ACT] The source code of scripts and formulas has been compiled successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Module ModArcBasic 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll
    2023-11-28 08:11:10 [B100][B100$][ACT] Module ModArcPostgreSql 6.1.1.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll
    2023-11-28 08:11:10 [B100][B100$][ACT] Module ModDbExport 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModDbExport.Logic.dll
    2023-11-28 08:11:10 [B100][B100$][ACT] Archive Cur initialized successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Archive Min initialized successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Archive Hour initialized successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Archive Events initialized successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Start listener on port 10000
    2023-11-28 08:11:10 [B100][B100$][INF] Archive in DAT format: C:\Program Files\SCADA\Archive
    2023-11-28 08:11:10 [B100][B100$][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy
    2023-11-28 08:11:10 [B100][B100$][ACT] Delete outdated data from the Min archive older than 28/11/2022
    2023-11-28 08:11:10 [B100][B100$][ACT] Delete outdated data from the Hour archive older than 28/11/2022
    2023-11-28 08:11:10 [B100][B100$][ACT] Delete outdated data from the Events archive older than 28/11/2022
    2023-11-28 08:11:54 [B100][B100$][ACT] Stop listener
    2023-11-28 08:11:54 [B100][B100$][ACT] Listener is stopped
    2023-11-28 08:11:54 [B100][B100$][ACT] Logic processing is stopped
    2023-11-28 08:11:54 [B100][B100$][ACT] Server is stopped
    2023-11-28 08:11:57 [B100][B100$][ACT] Server 6.1.1.1 started
    2023-11-28 08:11:57 [B100][B100$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll
    2023-11-28 08:11:57 [B100][B100$][ACT] Start logic processing
    2023-11-28 08:11:57 [B100][B100$][ACT] The configuration database has been read successfully
    2023-11-28 08:11:57 [B100][B100$][INF] Number of active channels for archiving: 335
    2023-11-28 08:11:57 [B100][B100$][INF] Number of active channels for sending commands: 0
    2023-11-28 08:11:57 [B100][B100$][ACT] Compile the source code of scripts and formulas
    2023-11-28 08:11:57 [B100][B100$][ACT] Added the following dependencies:
    2023-11-28 08:11:58 [B100][B100$][ACT] The source code of scripts and formulas has been compiled successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Module ModArcBasic 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll
    2023-11-28 08:11:58 [B100][B100$][ACT] Module ModArcPostgreSql 6.1.1.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll
    2023-11-28 08:11:58 [B100][B100$][ACT] Module ModDbExport 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModDbExport.Logic.dll
    2023-11-28 08:11:58 [B100][B100$][ACT] Archive Cur initialized successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Archive Min initialized successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Archive Hour initialized successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Archive Events initialized successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Start listener on port 10000
    2023-11-28 08:11:58 [B100][B100$][INF] Archive in DAT format: C:\Program Files\SCADA\Archive
    2023-11-28 08:11:58 [B100][B100$][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy
    2023-11-28 08:11:58 [B100][B100$][ACT] Delete outdated data from the Min archive older than 28/11/2022
    2023-11-28 08:11:58 [B100][B100$][ACT] Delete outdated data from the Hour archive older than 28/11/2022
    2023-11-28 08:11:58 [B100][B100$][ACT] Delete outdated data from the Events archive older than 28/11/2022
    2023-11-28 08:12:01 [B100][B100$][ACT] Session with ID -275528625156651192 created
    2023-11-28 08:12:01 [B100][B100$][ACT] Client 127.0.0.1 connected
    2023-11-28 08:12:01 [B100][B100$][ACT] User ScadaComm is successfully authenticated
    2023-11-28 08:12:03 [B100][B100$][ACT] Client 127.0.0.1 disconnected
    2023-11-28 08:12:04 [B100][B100$][ACT] Session with ID -2293832663858227796 created
    2023-11-28 08:12:04 [B100][B100$][ACT] Client 127.0.0.1 connected
    2023-11-28 08:12:04 [B100][B100$][ACT] User ScadaComm is successfully authenticated
    2023-11-28 08:13:53 [B100][B100$][ACT] Created event with ID 7306392348303855930 and channel 304
    2023-11-28 08:53:24 [B100][B100$][ACT] Created event with ID 7306402531278643967 and channel 304
    #13723
    The above is the content of ScadaServer.log
    Log files of the module are ModDbExport*.* in the same directory.
    • This reply was modified 2 years, 10 months ago by Mikhail.
    #13727
    KeanoC
    Here is a screenshot I took of what I assume your talking about. My export logs dont seem to be apearing
    #13728
    KeanoC
    And yes my module is active
    #13729
    KeanoC
    You could start with providing correct MySQL connection settings.
    Also check ModDbExport*.txt files.
    #13746
    KeanoC
    The 003 is from the mysql which im no longer using but the 002 has the correct string
    #13749
    In the module options disable Archive Replication for testing. Then check the log file.
    #13894
    Tecneira_monitoring
    Hi there Mikhail,
    I’m trying to export some channels values to a MySQL DB. By now I’ve already created a query in DBExport module and could export some of my project channels. The problem is that when I want to add new channels to query (channels 100000 to 100015 for example) this ones are not exported by Rapid Scada to my database.
    Here is an example of the query:
    Query
    And here a print of what is collected in the database:
    MySQL_DB
    Thank you in advance
    #13897
    I suggest to create a separate trigger that exports only the channels that are not exported. It would be useful to create a new table in the DB for them. It can help to realize the cause of the problem.
