Help witch formula
Forum Home › Forums › Understanding the Software › Formulas › Help witch formula
Viewing 8 posts - 31 through 38 (of 38 total)
  • #7220
    hethongscada62
    Hi Krzysztof,
    I have been tested formula with setting “Minute Real” type for 2 hours. But not result to get.
    https://ibb.co/20zgGfn
    https://ibb.co/Dz95F9P
    If you were tested it on your installation, i am testing it now with your suggest. To wait to get result.
    The best
    #7221
    Krzysztof
    Your result should be 0.1, but note that your measurement resolution is within 0.1, so with such a small increase in consumption your results may be 0.0 and sometimes 0.2
    #7222
    hethongscada62
    Dear Krzysztof,
    The formula was testing. It is a great, is working perfectly.
    Thank you for your help.
    I am still interested in sum formula. Could you suggest me what formula will be used to get the volume of water via water flow sensor (61 litres/minute).
    Thank you advance
    Han Hoang
    #7223
    Krzysztof
    What information do you read from the flow sensor? Are they pulses or an analog value of the current flow?
    #7224
    hethongscada62
    Hi Krzysztof,
    They are pulses sensor. The value gets via arduino nano.
    Han Hoang
    #7225
    Krzysztof
    hethongscada62
    Dear Mr.Mikhail,
    The rapid scada is reading the data per second, per minute and per hour from my flow sensor. Now i want to ask you: These data can get and display on scheme or on table?
    Thanks and best regards
    Han Hoang
    #7229
    Would you like to ask how to display data from archive?
    If yes, please create a new topic for discussing this question.
