Forum Home › Forums › Understanding the Software › Formulas › Continuing a calcuation after restart ?
- This topic has 18 replies, 4 voices, and was last updated 5 years, 10 months ago by
manjey73.
January 2, 2021 at 3:22 pm #7916
manjey73ParticipantRetain Formula for writing a variable to a file retain.txt
string pathRet = @"/opt/scada/ScadaServer/Config/retain.txt"; Dictionary<int, double> DictRet = new Dictionary<int, double>(); public double Retain (double ret) { DictRet[CnlNum] = ret; return ret; }Example of applying the formula in the input channel database. Retain(Val(150))
The control channel can contain setval(150, Cmd)The lowest input channel uses the load_retain formula
Recording in the loadret channel()bool initRet = false; double LoadRet() { if (!initRet) { if (System.IO.File.Exists(pathRet)) { string[] RetLoad = System.IO.File.ReadAllLines(pathRet, Encoding.UTF8); for (int i = 0; i < RetLoad.Length; i++) { SetVal(Convert.ToInt32(RetLoad[i].Substring(RetLoad[i].IndexOf("[")+1, RetLoad[i].IndexOf(", ")-(RetLoad[i].IndexOf("[")+1)),10),Convert.ToDouble(RetLoad[i].Substring(RetLoad[i].IndexOf(", ")+2,RetLoad[i].IndexOf("]")-(RetLoad[i].IndexOf(", ")+2)))); } initRet = true; } } return Convert.ToDouble(initRet); }Executed once at server startup
The most recent channel uses the save_retain formula
Entry in the saveret channel formula()double SaveRet() { string[] RetSave = new string[DictRet.Count]; bool eq = false; for (int i = 0; i < DictRet.Count; i++) { RetSave[i] = Convert.ToString(System.Linq.Enumerable.ElementAt(DictRet, i)); } if (!System.IO.File.Exists(pathRet)) { System.IO.File.WriteAllLines(pathRet, RetSave, Encoding.UTF8); return 0; } else { string[] RetOld = System.IO.File.ReadAllLines(pathRet, Encoding.UTF8); eq = System.Linq.Enumerable.SequenceEqual(RetOld, RetSave); if (!eq) { System.IO.File.WriteAllLines(pathRet, RetSave, Encoding.UTF8); } } return Convert.ToDouble(eq); }The path to Raspberry specify your own in the first formula.
An example file retain.txt[450, 23]
[451, 51]
[452, 51,5]
[453, 46]The first digit is the channel number, the second is the channel value.
The file is written when the variable specified as Retain is changed.
You can also initialize the necessary variables when starting the server.For changing variables in the process of work, but which need to be saved, it is better to add probably another timer and record no more than x minutes. I think so.
For configuration variables that rarely change, you can use as-is.January 2, 2021 at 3:27 pm #7917
manjey73Participant1st input channel use the formula – LoadRet()
Channels that require saving – Retain(Val(43))
Retain(here there can be a formula that returns necessarily double)In the last channel, the formula – SaveRet()
65535 use the formula – SaveRet()Any solution can lose value during a hard reboot, but if the variables do not change often, then you can use different options.
This reply was modified 5 years, 10 months ago by
manjey73.
January 2, 2021 at 3:29 pm #7918athes
ParticipantWow, really impressive.
Far more advanced then my solution 🙂January 2, 2021 at 3:32 pm #7920
manjey73ParticipantI do not know how advanced it is, it is better of course to use third-party applications for organizing RAM disk, which independently saves data to disk. Unlike tmpfs, as there are some limitations.
For example var stuffed into tmpfs does not allow xrdp to run
