Forum Home › Forums › Uncategorized Issues › Mail SMTP Set
- This topic has 17 replies, 6 voices, and was last updated 7 years, 2 months ago by
March 22, 2018 at 8:06 am #3330
leon
ParticipantHI
https://imgur.com/a/JGdQc
Please guide setting method Thanks!!March 22, 2018 at 6:01 pm #3331Joao
ParticipantYou can create a email group in Communicator> Device Libraries > double click KpEmail
then just send a command type 1 (binary) with this content:
group_name; subject; message
March 22, 2018 at 6:08 pm #3332Joao
ParticipantYou can use the module Automatic Control to send Emails automatcly. This can help: http://doc.rapidscada.net/content/en/modules/mod-auto-control.html
March 23, 2018 at 6:01 am #3335
See the description at Device Libraries – KpEmail.dll
You need a Binary command number 1 with a text that Joao noticed above.-
This reply was modified 8 years, 7 months ago by
March 23, 2018 at 6:09 am #3337leon
ParticipantJoan
Thank you for your reply but I’m still tryingMarch 23, 2018 at 7:55 am #3340leon
ParticipantHi Mikhail
I’m sorry I don’t really use
Is there a similar setting reference?Administrator>Devices>Call unmber need set email?
Communicator>Line 4>Request Sequence>Call unmber and Command line need set??March 23, 2018 at 3:12 pm #3342Joao
Participantyou are sending a command type Standard, It have to be binary
this is my configs:
March 23, 2018 at 5:28 pm #3350
MikhailModeratorleon, first of all, make sure that you can successfully send emails from Communicator. You don’t need other apps for testing, just Communicator. Send commands from the Command tab.
After you send emails from Communicator, you will setup Administrator and Automatic Control module.March 26, 2018 at 6:06 am #3358leon
Participanthi
Email has not been sent yet
https://imgur.com/a/tDWnsThank you very very much for your answers
March 26, 2018 at 12:54 pm #3362
I wrote:After you send emails from Communicator, you will setup Administrator and Automatic Control module.
So at the first, you should fix sending using Communicator only.
March 27, 2018 at 10:06 am #3365leon
Participanthi
I succeeded Thank you all!!Sending email notifications.
Commands:
1 (binary) – send the notification.Command text examples:
group_name;subject;message
contact_name;subject;message
email;subject;messageMarch 27, 2018 at 3:22 pm #3368
MikhailModeratorGreat 🙂
August 9, 2018 at 8:14 am #4108Gonederra
ParticipantI’ve got some probems with the SMTP server. It gives me this error:
Error sending email to *****@gmail.com: El servidor SMTP requiere una conexión segura o el cliente no se autenticó. La respuesta del servidor fue: 5.5.1 Authentication Required. Learn more at
It is translated to, the connection is not safe or the client could not be authentified.Am I configuring something wrong or is it something else?
I am just trying to send an email via Communicator with the commands as it is specified before in this thread.
Thanks.
August 9, 2018 at 3:16 pm #4110
MikhailModeratorGo to gmail account settings. Open the “Forwarding and POP/IMAP” tab and try enabling POP.
April 10, 2019 at 2:18 pm #5266jsanjose
ParticipantI’m experiencing the same problem.
Using Communicator I’m sending a test message using a gmail account. The log response is 5.5.1 Authentication Required. It’s a config problem.
Using SSL on SMTP Gmail server doesn’t work, using smtp.gmail.com on port 578 since this is de STARTTLS port. Nevertheless, 465 port doesn’t work neither (time exceded error).
Any ideas?
Thanks in advance.
