Current Data sudden become Not Ready
Forum Home › Forums › Runtime Bugs › Current Data sudden become Not Ready
Viewing 6 posts - 16 through 21 (of 21 total)
  • #14239
    kcks66
    Hi Mikhail,
    Pls advice for if I configure Automatic (Delayed Start) for Rapid SCADA’s services? Do you think if I delayed the Rapid SCADA from start running for 1 ~ 2 minutes after PC restart can solve the problem?
    https://ibb.co/T2NSq4d
    #14242
    It can be a good idea. Please let us know if it helps to solve the issue.
    #14247
    kcks66
    Hi Mikhail,
    Today I purposely tripped the PC power supply and later resumed power supply. I can see Rapid SCADA instance Server and Communicator services status Starting and then Normal.
    I checked Achieve status is all Ready, and data is writing into PostgreSQL database normally.
    I will continue monitor until next PC actual sudden shutdown happen and update here.
    #14257
    #14293
    kcks66
    Hi Mikhail,
    Today the PC encountered actual power supply tripped. The PC auto resume after around 30 minutes later. I checked Rapid SCADA and everything is working well.
    I think the Automatic (Delayed Start) setting worked.
    #14298
    That’s good! Thank you for the info.
