Silent server crash
Forum Home › Forums › Runtime Bugs › Server Bugs › Silent server crash
Viewing 7 posts - 16 through 22 (of 22 total)
  • #8191
    Please try this update. Does it help?
    #8217
    JW
    Hi Mikhail, I tested on the test project I uploaded for half hour each, with and without 1 sec delay on AutoControl. It seems working fine on both settings.
    Only need to update the server module, no need to update auto control module?
    #8223
    Yes. Commands are added to a queue inside the Server service and executed independently. That’s why they are not blocked.
    #8293
    JW
    does the above update also applied for linux version?
    there is a “ScadaServerSvc.exe” in the zip, but no “ScadaServerMono.exe”
    #8296
    Yes. It’s enough to update the *.dll files. ScadaServerMono.exe is just a shell to run the app.
    #8580
    zzz
    Hi Mikhail,
    Just checking back to see if RS has any progress on this?
    This is preventing us from puting RS into serious use at scale.
    The instablity makes it infeasible for reliable sync at anything 1s sync rate.
    I mean adding a delay to a command in the module settings, not to request. If delay is added, commands are added to a queue instead of being sent directly. The queue should protect the server app from hanging.
    Just curious, is this queue per output channel, per communication-line, per rule or per module?
    #8588
    Yes it is, see v5.1.4.2
    Server update for testing.
    The command queue is in the Server service.
    • This reply was modified 5 years, 6 months ago by Mikhail.
