Forum Home › Forums › Installation Issues › Webpage Error Localhost and Remote
- This topic has 15 replies, 2 voices, and was last updated 9 years ago by
October 31, 2017 at 4:48 pm #2725
Anonymous
InactiveInstallation on Windows 7. Webpage was working on Localhost and remote PCs. I shut the server down and moved it to its permanent location (On the same network) now web page will not load on either Localhost or remote PCs. Thanks for the help, Rob
Server Error in ‘/Scada’ Application.
Could not load type ‘System.ServiceModel.Activation.HttpModule’ from assembly ‘System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.TypeLoadException: Could not load type ‘System.ServiceModel.Activation.HttpModule’ from assembly ‘System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[TypeLoadException: Could not load type ‘System.ServiceModel.Activation.HttpModule’ from assembly ‘System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’.]
System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMarkHandle stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName, ObjectHandleOnStack type) +0
System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName) +70
System.RuntimeType.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark) +40
System.Type.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) +37
System.Web.Compilation.BuildManager.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) +65
System.Web.Configuration.ConfigUtil.GetType(String typeName, String propertyName, ConfigurationElement configElement, XmlNode node, Boolean checkAptcaBit, Boolean ignoreCase) +38[ConfigurationErrorsException: Could not load type ‘System.ServiceModel.Activation.HttpModule’ from assembly ‘System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’.]
System.Web.Configuration.ConfigUtil.GetType(String typeName, String propertyName, ConfigurationElement configElement, XmlNode node, Boolean checkAptcaBit, Boolean ignoreCase) +353
System.Web.Configuration.ConfigUtil.GetType(String typeName, String propertyName, ConfigurationElement configElement, Boolean checkAptcaBit) +21
System.Web.Configuration.Common.ModulesEntry.SecureGetType(String typeName, String propertyName, ConfigurationElement configElement) +39
System.Web.Configuration.Common.ModulesEntry..ctor(String name, String typeName, String propertyName, ConfigurationElement configElement) +42
System.Web.HttpApplication.BuildIntegratedModuleCollection(List`1 moduleList) +160
System.Web.HttpApplication.GetModuleCollection(IntPtr appContext) +1068
System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +82
System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +172
System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +339
System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +296[HttpException (0x80004005): Could not load type ‘System.ServiceModel.Activation.HttpModule’ from assembly ‘System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’.]
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +9946132
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +90
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +261October 31, 2017 at 7:23 pm #2728
MikhailModeratorPlease provide a screenshot of your Windows features dialog. I suppose, WCF was not installed.
November 3, 2017 at 10:46 am #2745
MikhailModeratorThe screenshot is not accessible.
November 3, 2017 at 2:02 pm #2748Anonymous
InactiveNovember 3, 2017 at 2:04 pm #2749Anonymous
InactiveNovember 3, 2017 at 2:07 pm #2752Anonymous
InactiveNovember 3, 2017 at 2:14 pm #2754Anonymous
InactiveNovember 3, 2017 at 2:18 pm #2755Anonymous
InactiveI added new links above. The fist two are Windows features. The next two are error on Localhost and error on Remote respectively. Thanks a bunch for the help.
November 4, 2017 at 12:44 pm #2759
MikhailModeratorDisable activations subitems of .Net 3.5.1 node. This is important.
November 6, 2017 at 7:44 pm #2764Anonymous
InactiveThat allowed the webpage to come up on Localhost but not on remote. Also the webpage log in page loads, I log in, the menus do not work, the scheme will not load, and a few seconds later the page closes and re-opens the Login page, consistently.
November 6, 2017 at 9:03 pm #2765Anonymous
InactiveCorrection. Remote computers net the same result as Localhost.
November 7, 2017 at 7:24 am #2766
MikhailModeratorPress F12 in the browser, quickly open the Console tab and make a screenshot.
November 7, 2017 at 4:56 pm #2771Anonymous
Inactivehttps://drive.google.com/file/d/1Dew4wIbM69nbS9ogzGePelqs7kpnwwkc/view?usp=sharing
Thank you very much for the help. If we can get this going reliably I might be interested in paying for support if those services are available.
November 8, 2017 at 1:01 pm #2772
MikhailModeratorI think, we haven’t repaired WCF (Windows Communication Foundation) yet.
Also make a screenshot of the http://localhost/scada/ClientApiSvc.svcWhen we work on Windows 7, WCF 4+ is installed as a part of .NET Framework. What version of .NET Framework is currently installed? Please make a screenshot of the installed programs where we can see Microsoft .NET.
The most fresh framework is 4.7.1. I recommend to update to this version from https://www.microsoft.com/net/download/windowsNovember 8, 2017 at 3:40 pm #2776Anonymous
InactiveThe .NET update fixed it. Thanks again for the great support!!!
