Forum Home › Forums › Installation Issues › SCADA-Web Installation › Installation failure
- This topic has 19 replies, 2 voices, and was last updated 5 years, 3 months ago by
July 13, 2021 at 3:11 pm #9240
lilytech
ParticipantHave set as required, but fail to install.
The log file:Rapid SCADA 5.8.3 Installation
Create directory C:\SCADA\Install Server application
Unzip files from D:\Works\C#\RapidScada\v5.8.3\scada_5.8.3_full_en\Arc\ScadaServer.zip
Install service ScadaServerService
Process completed with an error
Installation of Server application has completed with a error:
Service ScadaServerService hasn’t been installedInstall Communicator application
Unzip files from D:\Works\C#\RapidScada\v5.8.3\scada_5.8.3_full_en\Arc\ScadaComm.zip
Install service ScadaCommService
Installation of Communicator application has completed with a error:
Service ScadaCommService hasn’t been installedCheck the configuration of Internet Information Services (IIS)
Go to
Control Panel > Programs > Turn Windows features on or off
and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
whereas the components for .NET Framework 3.5 are switched off
Check Windows Communication Foundation (WCF)
Register ASP.NET
Install Webstation application
Unzip files from D:\Works\C#\RapidScada\v5.8.3\scada_5.8.3_full_en\Arc\ScadaWeb.zip
Selected application pool: DefaultAppPool
Register web application Scada
Create shortcut Webstation
Installation of Webstation application has completed successfullyInstall Agent application
Unzip files from D:\Works\C#\RapidScada\v5.8.3\scada_5.8.3_full_en\Arc\ScadaAgent.zip
Install service ScadaAgentService
Installation of Agent application has completed with a error:
Service ScadaAgentService hasn’t been installedInstall Administrator application
Unzip files from D:\Works\C#\RapidScada\v5.8.3\scada_5.8.3_full_en\Arc\ScadaAdmin.zip
Create shortcut Administrator
Installation of Administrator application has completed successfullyInstall Scheme Editor application
Unzip files from D:\Works\C#\RapidScada\v5.8.3\scada_5.8.3_full_en\Arc\ScadaSchemeEditor.zip
Installation of Scheme Editor application has completed successfullyInstall Table Editor application
Unzip files from D:\Works\C#\RapidScada\v5.8.3\scada_5.8.3_full_en\Arc\ScadaTableEditor.zip
Installation of Table Editor application has completed successfullyInstallation has completed with errors
Please restart the computerJuly 13, 2021 at 3:36 pm #9241
MikhailModeratorTo fix installation do the items 7-9 by this link.
In case of errors, provide info.July 14, 2021 at 1:43 am #9244lilytech
ParticipantAll settings for windowns are as required, except:
in the help file, asp.net 4.6, wile my PC is asp.net 4.8Although the automatic installation result is same, failure, I try to run.
after browse:
http://localhost/scada/
enter “admin” and “12345”, the webpage shows: “Server is unavailable”?July 14, 2021 at 1:00 pm #9253
MikhailModeratorasp.net 4.6, wile my PC is asp.net 4.8
It’s OK.
What did you get exactly after the actions below?
7. Register ScadaServerService by executing ScadaServer\svc_install.bat as administrator.
8. Register ScadaCommService by executing ScadaComm\svc_install.bat as administrator.
9. Register ScadaAgentService by executing ScadaAgent\svc_install.bat as administrator.July 15, 2021 at 2:11 am #9258lilytech
ParticipantAfter the up action excuted, Login still shows: “Server is unavalilable”
July 15, 2021 at 11:00 am #9259
MikhailModeratorI mean, what do you get in command window when execute *.bat files?
July 15, 2021 at 1:51 pm #9263lilytech
Participant1. ScadaServer\svc_install.bat
C:\SCADA\ScadaServer>svc_installC:\SCADA\ScadaServer>cd /d “C:\SCADA\ScadaServer\”
C:\SCADA\ScadaServer>C:\Windows\Microsoft.NET\Framework\v4.0.30319\InstallUtil.exe ScadaServerSvc.exe
Microsoft (R) .NET Framework 安装实用工具版本 4.8.4084.0
版权所有 (C) Microsoft Corporation。保留所有权利。正在运行事务处理安装。
正在开始安装的“安装”阶段。
查看日志文件的内容以获得 C:\SCADA\ScadaServer\ScadaServerSvc.exe 程序集的进度。
该文件位于 C:\SCADA\ScadaServer\ScadaServerSvc.InstallLog。
正在安装程序集“C:\SCADA\ScadaServer\ScadaServerSvc.exe”。
受影响的参数是:
logtoconsole =
logfile = C:\SCADA\ScadaServer\ScadaServerSvc.InstallLog
assemblypath = C:\SCADA\ScadaServer\ScadaServerSvc.exe
正在安装服务 ScadaServerService…
已成功安装服务 ScadaServerService。
正在日志 Application 中创建 EventLog 源 ScadaServerService…“安装”阶段已成功完成,正在开始“提交”阶段。
正在提交程序集“C:\SCADA\ScadaServer\ScadaServerSvc.exe”。
受影响的参数是:
logtoconsole =
assemblypath = C:\SCADA\ScadaServer\ScadaServerSvc.exe“提交”阶段已成功完成。
已完成事务处理安装。
C:\SCADA\ScadaComm>svc_install
C:\SCADA\ScadaComm>cd /d “C:\SCADA\ScadaComm\”
C:\SCADA\ScadaComm>C:\Windows\Microsoft.NET\Framework\v4.0.30319\InstallUtil.exe ScadaCommSvc.exe
正在开始安装的“安装”阶段。
查看日志文件的内容以获得 C:\SCADA\ScadaComm\ScadaCommSvc.exe 程序集的进度。
该文件位于 C:\SCADA\ScadaComm\ScadaCommSvc.InstallLog。
正在安装程序集“C:\SCADA\ScadaComm\ScadaCommSvc.exe”。
受影响的参数是:
logtoconsole =
logfile = C:\SCADA\ScadaComm\ScadaCommSvc.InstallLog
assemblypath = C:\SCADA\ScadaComm\ScadaCommSvc.exe
正在安装服务 ScadaCommService…
已成功安装服务 ScadaCommService。
正在日志 Application 中创建 EventLog 源 ScadaCommService…“安装”阶段已成功完成,正在开始“提交”阶段。
正在提交程序集“C:\SCADA\ScadaComm\ScadaCommSvc.exe”。
受影响的参数是:
logtoconsole =
assemblypath = C:\SCADA\ScadaComm\ScadaCommSvc.exe“提交”阶段已成功完成。
已完成事务处理安装。
C:\SCADA\ScadaComm>
C:\SCADA\ScadaAgent>svc_install
C:\SCADA\ScadaAgent>cd /d “C:\SCADA\ScadaAgent\”
C:\SCADA\ScadaAgent>C:\Windows\Microsoft.NET\Framework\v4.0.30319\InstallUtil.exe ScadaAgentSvc.exe
正在开始安装的“安装”阶段。
查看日志文件的内容以获得 C:\SCADA\ScadaAgent\ScadaAgentSvc.exe 程序集的进度。
该文件位于 C:\SCADA\ScadaAgent\ScadaAgentSvc.InstallLog。
正在安装程序集“C:\SCADA\ScadaAgent\ScadaAgentSvc.exe”。
受影响的参数是:
logtoconsole =
logfile = C:\SCADA\ScadaAgent\ScadaAgentSvc.InstallLog
assemblypath = C:\SCADA\ScadaAgent\ScadaAgentSvc.exe
正在安装服务 ScadaAgentService…
已成功安装服务 ScadaAgentService。
正在日志 Application 中创建 EventLog 源 ScadaAgentService…“安装”阶段已成功完成,正在开始“提交”阶段。
正在提交程序集“C:\SCADA\ScadaAgent\ScadaAgentSvc.exe”。
受影响的参数是:
logtoconsole =
assemblypath = C:\SCADA\ScadaAgent\ScadaAgentSvc.exe“提交”阶段已成功完成。
已完成事务处理安装。
July 16, 2021 at 12:44 pm #9268
MikhailModeratorI don’t understand what is written in Chinese.
Run services.msc and make sure that ScadaServerService exists in the list.
July 16, 2021 at 12:50 pm #9271
MikhailModeratorYou could also ask in this new subforum.
July 17, 2021 at 12:36 am #9273lilytech
ParticipantToday, it works.
July 17, 2021 at 6:59 am #9274
MikhailModeratorOK
July 26, 2021 at 2:48 am #9291lilytech
ParticipantDear
I have read all in rapidscada.org, and rapidscada.net,
but I still fail to build my project.The document in rapidscada.net is like datasheet, instead of instruction for application.
Is there any step by step books for us to build our project, very simple project, to audit many modbus incubator slaves?July 26, 2021 at 8:15 am #9292July 26, 2021 at 8:28 am #9297lilytech
ParticipantI have browsed some of them.
It seems too hard to work after watched.Thanks.
July 26, 2021 at 8:45 am #9298lilytech
ParticipantIf we invite you to make a project:
audit many modbus incubator’s temperature and humidity.
can check historical data.
no nice graphics is necessary, only stable, easy to use is ok.What will be the price?
