Mobile client and Rapid SCADA
Forum Home › Forums › Development and Integration › Mobile client and Rapid SCADA
Viewing 13 posts - 16 through 28 (of 28 total)
  • #6814
    Port forwarding for example
    Checking the IP provider, it is not a fact that you will be able to connect to it, since it may be for NAT
    For example, routers Zyxel, Mikrotik and perhaps others have a cloud service to access them, then instead of an IP address, you need to know the name that the router manufacturer provides you with
    xxxxxxxxxxxa.sn.mynetname.net – On my Mikrotik it looks like this (instead of xxxxx numbers)
    #6819
    arvxn01
    Hello @manjey73,
    I have a router from SFR and there is no cloud service integrated. Maybe I need to try noip.com as Mikhail said :
    “Also you can use dynamic DNS service, such as https://www.noip.com/ In this case, you need to register the service, enter the credentials into your router, setup NAT on the router, and then connect like youraddress.ddns.net/scada”
    I will try this solution.
    #6821
    arvxn01
    Thanks you @manjey73 !
    Port forwarding is the solution for my project. I use noip.com to bypass dynamic IP adress and access when I went to my webserver using ports 80 and 443.
    #6822
    Hennie_Kotze
    Dear @arvxn01,
    In my case I had to request my service provider (Vodacom) to change my restricted APN to UN-restricted. Even while using noip, it did not work through the restricted APN.
    Hope it helps??…….
    Regards,
    #6823
    There are just real dynamic addresses, and there are dynamic addresses located behind the provider’s NAT. In the second case, only cloud services or VPN services can help (but I have not met third-party vpn services that would allow you to connect two clients to each other)
    #6824
    arvxn01
    Good morning,
    I set up port forwarding on my router and I use noip.com to haven’t problem with the dynamic IP adress of my router.
    For my project, everything work perfectly ! Thanks to @manjey73 and @Hennie_Kotze ! I can connect to the webstation on my iPhone even if I use cellular network.
    [1 question remaining]: I saw on my iPhone and on my PC that the connection is not secured. Is it possible to change settings to have a secured connection or there is no way ?
    #6825
    You need to transfer Apache2 or IIS to work on https. I didn’t do this myself, but the topic on the Russian forum may help, and Mikhail will write more details
    work _ https
    • This reply was modified 6 years, 6 months ago by manjey73.
    #6829
    There is another option, you disable the web port forwarding. Create a VPN server on your router. When you need to, connect via your phone as a VPN client and then go to the WEB at the internal address of your server. The VPN client must be able to route the connection to the internal network. One of the advantages of this solution, depending on the settings, your phone when accessing the Internet will be determined with the IP that you have at home
    #6840
    arvxn01
    Good morning,
    I have 2 questions :
    1) How can i create a new topic ?
    2) I need to setup two webstations. One with buttons, switchs and leds. And the other one will show a part of a production line with engines, and others devices. These webstations need to communicate using Internet. How can I do this installation with RapidScada ?
    #6841
    arvxn01
    I try to use many instances inside the same project but i didn’t succeed. I didn’t find any video about instances. Can you explain me how i can use many instances in the same project. And what i can do with many instances ?
    For now, when i create a profile for a new instance, he doesn’t work and the error says “Unable to login – System instance not found”.
    #6842
    Click the appropriate subforum, scroll the page down, fill and submit the form.
    Please create a new topic for this question.
    #6858
    arvxn01
    Hey @manjey73 @Mikhail @Hennie_Kotze
    I have 2 computers with Rapid SCADA so 2 different projects.
    The 1st project for simulating. And the 2nd project for control the simulated system. I don’t know if I need to use port forwarding on my router or use the firewall with advanced settings ? Because, I want the 2nd project controls the simulated system using Internet connection.
    Please for your future answer 🙂
    #6862
    Topic is duplicated. Use this link.
