Viewing 15 posts - 5,671 through 5,685 (of 6,282 total)
  • in reply to: Read File Record #1550
    The current version of Modbus driver can not send custom (non standard) commands.
    Imagine it is implemented. What format of the response will be received? How to decode the response and process it?
    in reply to: Automatic Control Module integration #1547
    Thank you for the info ))
    Did you use the formula with CmdVal in OUTPUT channel?
    How do you set a new value from UI?
    • This reply was modified 9 years, 10 months ago by Mikhail.
    in reply to: Automatic Control Module integration #1545
    Is is possible to write variables to log.
    Add formula:
    void WriteToLog(string s)
      using (System.IO.StreamWriter writer =
        new System.IO.StreamWriter(@"C:\SCADA\mylog.log", true, Encoding.UTF8))
        writer.WriteLine(s);
    Then you can use WriteToLog(hour.ToString()) within other formulas.
    in reply to: Automatic Control Module integration #1544
    I created another input channel to display the CmdVal of the output channel which uses SetHour().
    What is the number of that channel on the screenshots?
    How do you expect to behave for input channels 61, 62? Are they received from your device?
    in reply to: Automatic Control Module integration #1543
    Please describe how do you send command to set hour?
    in reply to: Automatic Control Module integration #1541
    I recommend to create input channels to show current values of hour and minute variables in order to control them.
    in reply to: Automatic Control Module integration #1540
    Apparently the calculated channel data never appears correctly in the Scada Comm device data which I was using to check the data changes. It only appears in Scada Web.
    Definitely 🙂
    Now how can I send the hour and minute parameters from the output channel to my flag channel ?
    Add the variables into Formulas table:
    int hour = 0;
    int minute = 0;
    Add the code into Formulas table:
    double SetHour()
      hour = (int)CmdVal;
      return double.NaN;
    Use the above formula for an output channel.
    Note: I don’t test code which I write in this forum. It’s just a direction for experiments.
    in reply to: Automatic Control Module integration #1538
    It’s strange. Did you pass the changes to Server and restart Server service?
    Try simplifying the formula of an input channel.
    First of all, try the formula: 1
    Then try: DateTime.Now.Minute
    in reply to: How to get the data from a RS232 device? #1536
    Send me, please, an email request for price estimation. Also attach full description of the communication protocol.
    Email address is here
    in reply to: How to get the data from a RS232 device? #1534
    You need to develop by yourself or purchase development of a device driver.
    Read Device Drivers Development
    Source code examples are here
    in reply to: How to get the data from a RS232 device? #1532
    What communication protocol is supported by the device?
    in reply to: Automatic Control Module integration #1531
    I didn’t write: you have to change channel type to Calculated real.
    in reply to: Automatic Control Module integration #1528
    I mean that you should enter the whole CheckTime() function in Formulas table. Then enter just CheckTime() in Input channels table.
    in reply to: Automatic Control Module integration #1525
    The simple formula example:
    double CheckTime()
      DateTime nowDT = DateTime.Now;
      return nowDT.Hour == 1 && nowDT.Minute == 0 ? 1 : 0;
    in reply to: Automatic Control Module integration #1524
    In formulas you can use DateTime and TimeSpan
