MikhailModeratorRapid SCADA contains all the necessary features to implement this. You don’t need OPC server and other 3rd party software.
This is a one of common scenarios. Do you have detailed questions?April 5, 2017 at 6:23 am in reply to: Different Registers Showing Same Value Until Comm Restart #2075
MikhailModeratorMany thanks for the feedback 🙂
Probably, TCP port 10000 is already opened by another application. Use TCP View utility to check it. See this link.
If you’d like to get answers in Russian, ask on http://forum.rapidscada.ru/March 31, 2017 at 6:22 pm in reply to: How can I make SCADA pull data when it receives triggers from my PLC #2071
MikhailModeratorHi Marty,
I sent you the key by Skype.March 31, 2017 at 5:33 am in reply to: Different Registers Showing Same Value Until Comm Restart #2069
MikhailModeratorTry increasing Delay parameter for the device in Communicator up to 1000 ms.
March 31, 2017 at 5:31 am in reply to: Different Registers Showing Same Value Until Comm Restart #2068
MikhailModeratorI can see that the equal response comes back twice from the device. If requested number of register differs (the last 2 bytes), it causes PDU length error. If it’s equal, Communicator can’t detect an error. You can get the meaning of bytes by http://modbus.rapidscada.net/
Do you have any idea, why the device responses twice?
First of all, check the existence of data in the file h170331.dat using Server user interface as you did earlier.
MikhailModeratorCan you check the installed Silverlight? Open this website using Internet Explorer. Does it work?
MikhailModeratorVery interesting information. Thank you.
I think, the most simple way is changing user for ScadaServerService and ScadaCommService. Pay attention, that the user must be PC administrator.March 30, 2017 at 6:24 am in reply to: Different Registers Showing Same Value Until Comm Restart #2061
MikhailModeratorAlso open the Server app, go to Files > Hourly Data, and compare the values in the archive. Are they equal starting from some moment? Provide screenshots, please.
March 30, 2017 at 6:22 am in reply to: Different Registers Showing Same Value Until Comm Restart #2060
Let’s compare the packets sent to and received from the devices. You can copy the communication log from C:\SCADA\ScadaComm\Log\lineXXX.log
Rapid SCADA installation package contains Silverlight x64. I think, you should download and install Silverlight x32.
MikhailModeratorSuch a funny bug. Do you have any idea why the current year for the user system is 2560?
Please, see C:\SCADA\ScadaComm\Log\ScadaCommSvc.log Is there 2560 year too?
The applications that have graphical user interface work as your logged in user, whereas Server and Communicator services work as system.
Try opening Control Panel > Administrative Tools > Services and changing the user for ScadaServerService and ScadaCommService
MikhailModeratorFile name is a date YYMMDD. It’s strange that the files were created like your current year is 1960.
Could you see Minute Data, are the files also have names like m60xxxx.dat?
Please post here a content of C:\SCADA\ScadaServer\Log\ScadaServerSvc.txt -
