MikhailModerator// 1. Reset
// 2. Set percent
// 3. AckIf you need to send 3 values to the device by a single command, definitely you need Auto Control Module. It splits an initial command into 3 commands.
MikhailModeratorI suppose, SetData should not be there.
An output formula just returns a command value that is passed to Communicator.
MikhailModeratorMaybe it should be a component that translates others.
The formula looks incorrect. It should return a double value or byte array, and used as an output formula of the channel. SetVal and SetData are used to set channel value, not for sending commands.
To use address 0, there should be a separate device. Try sending commands by the Administrator app to that device, and control the results in communication line log.
MikhailModerator2. This is complex. Possible approach is storing a string table as a mimic dependency. It is also requires more work made by an engineer who create a mimic.
The economic feasibility of this work is unclear. There are many tasks that seem to be a higher priority for implementation.
1. This is technically possible. However it requires a lot of work, because all web forms will be affected. Currently, only one culture is loaded when the web app start. A new mechanism for loading multiple languages should be developed.
Since ASP Razor Pages renders pages on the server side, switching language will require page reload.
MikhailModeratorIt may be related to the certificate. Try to get information from the OPC server to understand how it sees the client trying to connect.
MikhailModeratorWhat are the use-cases? Do you mean an implementation when users from different countries connect to the same Rapid SCADA instance?
Let’s specify the requirement more precisely.
Do you mean to implement an option that lets a user to select a language individually?
How it should work for mimics?
What is the error message in the screenshot?
For some reason, the screenshot is in bad quality.
I have some thoughts about that.
Please create a new topic to discuss the new idea.-
This reply was modified 1 month, 2 weeks ago by
MikhailModeratorThank you for the update 🙂
MikhailModeratorThe difficulties that have arisen are a little strange. Please let us know what you find.
