MikhailModeratorByte order in the Modbus template is 76543210
I managed to make it work:
https://ibb.co/82BgRvJ
https://ibb.co/7nHQ7Hn
https://ibb.co/sb4vvyk
https://ibb.co/m4MdhqY
https://ibb.co/GTG0P8Z
You should check log files of the module.
Rapid SCADA 6: Create new formats in the Formats table. Use the created format for a channel. See Off-On as an example.
Rapid SCADA 5: the same, but add new rows to the Units table.
This reply was modified 3 years, 2 months ago by
MikhailModeratorIn logs you can find timestamps of all command steps.
A command goes the following way: Webstation – Server – Communicator – Device.
Using the logs, analyze why it takes too long.
May be a command waits while Communicator ends a current polling session.
Could you make screenshots of the channels, Modbus template, and device data (in Communicator)?
Could you try the following:
1. In Modbus template change element’s data type to ulong (8 bytes)
2. Update channel data type to Integer, and set channel format to Hexadecimal
This can help to check the actual channel values.
See https://ibb.co/JkXJSmJ
Could you publish a screenshot where a link component is added to a scheme, and it’s properties are displayed in the properties table?
Change the channel data type to blank (double) to get large numbers.
Then add a new channel of the Calculated type, string data type and an input formulaData(101), where 101 is the source channel number.
Send screenshots of the settings and results.
Use the existing plugins as samples. In case of particular questions, ask.
We can provide a personal online training if needed.-
April 6, 2023 at 8:59 am in reply to: How can I edit the source code of the scheme editor in v6 #12383
Open Task Manager and check CPU usage of different applications.
I don’t think it’s possible, because Server is a service that has no access to desktop. Web application also has no access to a desktop. It’s only possible to start a console application from Server script. -
