Viewing 15 posts - 31 through 45 (of 6,270 total)
  • in reply to: Chart X-axis timeline seeting #17887
    Labels that contain timestamps are generated automatically. I suppose, “11:00” has smaller font width, so it was inserted between 10 and 12.
    Thank you for bringing this potential issue to attention. I’ll look into it and post in this topic. This will take some time.
    in reply to: Setting multiple channels at once. #17884
    // 1. Reset
    // 2. Set percent
    // 3. Ack
    If you need to send 3 values to the device by a single command, definitely you need Auto Control Module. It splits an initial command into 3 commands.
    in reply to: Setting multiple channels at once. #17883
    I suppose, SetData should not be there.
    An output formula just returns a command value that is passed to Communicator.
    in reply to: Multi language support #17881
    Maybe it should be a component that translates others.
    in reply to: Setting multiple channels at once. #17879
    The formula looks incorrect. It should return a double value or byte array, and used as an output formula of the channel. SetVal and SetData are used to set channel value, not for sending commands.
    To use address 0, there should be a separate device. Try sending commands by the Administrator app to that device, and control the results in communication line log.
    in reply to: Multi language support #17878
    2. This is complex. Possible approach is storing a string table as a mimic dependency. It is also requires more work made by an engineer who create a mimic.
    The economic feasibility of this work is unclear. There are many tasks that seem to be a higher priority for implementation.
    in reply to: Multi language support #17877
    1. This is technically possible. However it requires a lot of work, because all web forms will be affected. Currently, only one culture is loaded when the web app start. A new mechanism for loading multiple languages should be developed.
    Since ASP Razor Pages renders pages on the server side, switching language will require page reload.
    in reply to: Communication via port forwarding not working #17876
    It may be related to the certificate. Try to get information from the OPC server to understand how it sees the client trying to connect.
    in reply to: Multi language support #17869
    What are the use-cases? Do you mean an implementation when users from different countries connect to the same Rapid SCADA instance?
    in reply to: Multi language support #17868
    Let’s specify the requirement more precisely.
    Do you mean to implement an option that lets a user to select a language individually?
    How it should work for mimics?
    in reply to: Communication via port forwarding not working #17867
    What is the error message in the screenshot?
    For some reason, the screenshot is in bad quality.
    in reply to: modal develop in mimiceditor #17862
    I have some thoughts about that.
    Please create a new topic to discuss the new idea.
    • This reply was modified 1 month, 2 weeks ago by Mikhail.
    in reply to: DrvDDEJP #17861
    To add the driver to the Store, fill the form specified here.
    in reply to: Error Communication Failed #17860
    Thank you for the update 🙂
