Viewing 15 posts - 901 through 915 (of 921 total)
  • in reply to: Web application output value #2441
    In the output channel specified formula SetVal(65, Cmd)
    In CalcEngine.cs entry looks like this:
    public void CalcCmdVal65(ref double cmdVal) { try { BeginCalcCmdData(65, cmdVal, null); cmdVal = Convert.ToDouble(SetVal(65,Cmd)); } finally { EndCalcCmdData(); }}
    Why do you have so ?
    Convert.ToDouble(SetVal(102,1))
    in reply to: Web application output value #2434
    Do not use the entry formula in the actual (real) input channel.
    What do you have in the specified row CalcEngine.cs ?
    • This reply was modified 8 years, 8 months ago by manjey73.
    in reply to: Webstation error occures when formulas realize #2410
    To fix the formula, since the formula is incorrect Server will not start.
    scada/ScadaServer/Log/scadaServerSVC.log
    To see what error and in what line of the file CalcEngine.cs
    in reply to: Send Setpoint value (float number) #2406
    All formulas return a double, but to enumerate the possible integer values only.
    On; Off; Reset values 0, 1 and 2
    ; Off; Reset values 1 and 2 appear to have two buttons Off and Reset
    In the output channel to be used in the formula Cmd*100 (example)
    Or write more complex formula in the database of formulas, call it for example Out_real, and to apply the output channel Out_real(Cmd)
    Where is Cmd will get the values 0, 1 or 2 and depending on them you will return the desired value.
    Using Formulas
    in reply to: Send Setpoint value (float number) #2400
    When transferring 10;50.5;101.5 are values, this is the text for the buttons.
    The value is precisely 0 , 1 and 2
    Need for a control channel to write a formula that will check the value 0,1 or 2 and substitute these values instead of the required 10, 50.5 или101.5
    And may also have the formula of permutation bytes, if you work directly with the device. With OPC has faced, may not require.
    in reply to: Change "Signal" number #2391
    Our database create different KP for the same type of devices.
    Call Number list for each device as well in the database.
    When you specify the device Bound and the KP number the Call Number is taken from the database (priority when the flag Bound)
    Tab Request Sequence, create a few queries and specify the settings for each device. The binding channels will occur at the number KP, and the signal numbers
    https://s3.postimg.org/wy7mr4xpv/Modbus_1.png
    in reply to: Change "Signal" number #2388
    Just have devices with the same templates should be different KP in the database
    in reply to: IEEE 754 floating point ?? #2385
    Connecting Devices Using Modbus Protocol
    Element parametrs
    float(4 bytes)
    Byte orders, you must specify your sequence of bytes, for example 2301
    In the initial group element specifies the starting register in the survey. Depending on the equipment it may be necessary to the starting address add 1
    in reply to: Creating interface and connecting to devices #2380
    To work in real-time as the PLC it is necessary to apply the formula in the input channels and use Automatic Control Module.
    Unfortunately the module is not able to transmit an arbitrary value, only fixed.
    Study the documentation and try to implement their ideas.
    Documentation
    in reply to: Login to software with cell-phone browser or another PC #2372
    ping is not related to the operation of the scada system, it can be closed in the firewall.
    In this case the SCADA will work fine
    in reply to: Login to software with cell-phone browser or another PC #2367
    Try to disable the firewall.
    in reply to: if variable change value every minute so 1 , otherwise 0 #2365
    I have used several formulas to control the state of the PC when reading parameter UpTime via SNMP Protocol.
    Need formula Ticks, Ton, NotEquals our database formulas.
    The challenge in the formula of the channel NotEquals(Val(602),120000), where Val(602) controlled signal, the time in milliseconds
    _______________________________________________
    Ticks (Returns the time in milliseconds required for the operation of the timer Ton)
    public static long Ticks()
    DateTime now = DateTime.Now;
    long time = now.Ticks/10000;
    return time;
    ________________________________________________
    Ton (Timer with delay)
    int[] TonNum = new int[1];
    long[] TonST = new long[1];
    bool[] TonFlag = new bool[1];
    public double Ton(double TonIn, double TonPT)
    long ET = 0L;
    long ton_pt = Convert.ToInt64(TonPT);
    bool q = Val(CnlNum) > 0;
    bool ton_in = TonIn > 0;
    int res = Array.IndexOf(TonNum, CnlNum);
    if (res == -1)
    res = TonNum.Length;
    Array.Resize(ref TonNum, res+1);
    Array.Resize(ref TonST, res+1);
    Array.Resize(ref TonFlag, res+1);
    TonNum[res] = CnlNum;
    if (!ton_in)
    q = false;
    TonFlag[res] = false;
    TonST[res] = 0L;
    else
    if (!TonFlag[res])
    TonFlag[res] = true;
    TonST[res] = Ticks();
    else
    if (!q) ET = Ticks() – TonST[res];
    if (ET >= ton_pt) q = true;
    return Convert.ToDouble(q);
    ______________________________________________________________
    NotEquals (If the value has not changed within the specified time in milliseconds, then the channel returns 1 if the time is changed, the timer resets)
    int[] NotEqualsNum = new int[1];
    bool[] valEquals = new bool[1];
    double[] valUpTime = new double[1];
    public double NotEquals(double UpTime, double PT)
    bool eq = false;
    int res = Array.IndexOf(NotEqualsNum, CnlNum);
    if (res == -1)
    res = NotEqualsNum.Length;
    Array.Resize(ref NotEqualsNum, res+1);
    Array.Resize(ref valEquals, res+1);
    Array.Resize(ref valUpTime, res+1);
    NotEqualsNum[res] = CnlNum;
    valUpTime[res] = UpTime;
    valEquals[res] = q;
    eq = (UpTime – valUpTime[res]) > 0 ;
    double tonIn = Convert.ToDouble(!eq);
    valEquals[res] = Convert.ToBoolean(Ton(tonIn, PT));
    return Convert.ToDouble(valEquals[res]);
    _________________________________________________________________________
    2 minutes = 120000 milliseconds
    in reply to: Login to software with cell-phone browser or another PC #2364
    IP/scada from local network
    To configure NAT on the router. For example, port 9090 to port 80 for IIS.
    Static IP:9090/scada
    Or port 8084 to 8084 port for mono-xsp4 on Linux
    Static IP:8084/scada
    If not mistaken, this functionality is not currently implemented and planned in the future.
    in reply to: Function to Send Command #2314
    To be able to send commands to the device after executing the formulas in the input channels required Automatic Control Module
