manjey73Participanthttps://github.com/Manjey73/OpnenKPs/blob/master/KpRpi3/Readme.md
Have you read the description in English from the link above ?
Executed the command sudo gpio readall ? The given command will display the table of numbering of the contacts in BCM format and GPIO format. When you configure channels on Windows, the channels are numbered in BCM format. The output of this command you can understand which pin number corresponds to bcm numbering.
https://i.stack.imgur.com/h4rgc.png – It is necessary to focus on the BCM numbering
manjey73ParticipantCan you catch and fix a screenshot ? Just online translation I do not understand what you mean ?
manjey73Participantdouble Scaler (double input, double in_min, double in_max, double out_min, double out_max) { double out1 = 0; double out2 = 0; double output = 0; double diff = in_max - in_min; if (diff != 0) { if (input > in_max) out1 = in_max; else out1 = input; if (in_min > out1) out2 = in_min; else out2 = out1; output = (out_max - out_min) / diff * (out2 - in_min) + out_min; } return output; }This site automatically changes the minus sign on the dash. Try to rewrite the formula from the code or correct hands.
The entry of the formula seems correct
manjey73ParticipantWhen you start Communicator and Server, it does not open the program window, but it starts minimized and its icons are located in the system tray
manjey73ParticipantCommunicator runs in the system tray, we take account of it.
manjey73ParticipantYou need to set the connection driver in the xml file by specifying the bit mask settings.
example ScadaCommSvcConfig.xml
<!--Линия 6--> <CommLine active="true" bind="true" number="6" name="RPi"> <CommChannel type="" /> <LineParams> <Param name="ReqTriesCnt" value="1" descr="Количество попыток перезапроса КП при ошибке" /> <Param name="CycleDelay" value="0" descr="Задержка после цикла опроса, мс" /> <Param name="CmdEnabled" value="true" descr="Команды ТУ разрешены" /> <Param name="ReqAfterCmd" value="false" descr="Опрос КП после команды ТУ" /> <Param name="DetailedLog" value="true" descr="Записывать в журнал подробную информацию" /> </LineParams> <CustomParams /> <ReqSequence> <KP active="true" bind="true" number="52" name="GPIO Raspberry" dll="KpRpi3.dll" address="1" callNum="" timeout="1000" delay="200" time="00:00:00" period="00:00:00" cmdLine="268435439;268435455;268435455;268435455;1;" /> </ReqSequence> </CommLine>It is also necessary to specify the communication line in the databases of the Scada server using a Windows PC and then transferred to the Raspberry Pi. You can also customize and Communicator
manjey73ParticipantOn Raspberry Pi2 was not tested work with GPIO, if you have Pi2 B+, then the numbering of GPIO must be the same. You can check it using the utility.
sudo gpio readallThis way you will get a table of outputs and outputs of your version of Raspberry. Then connect the driver to the Windows PC and start the settings. Disable the checkbox in the use GPIO column on unused inputs or outputs, determine the remaining destination input or output as well as power lift.
The driver uses the WiringPi library and does not access GPIO directly.
manjey73Participantthe easiest way is to install mc, copy by any means to the user’s Downloads folder. Then in root mode run mc and copy anywhere you want. Then change the permissions and the user to the necessary folders using the chmod, chown commands
manjey73ParticipantChannel number 1000 – evaluation X
Then your formula in the channel 1022 – Val(1001)+Val(1021)*Val(1000)
manjey73ParticipantYou need to channel to find the value of X knowing Val(1001) and Val(1021) ? Then you need to know the answer
Or do you need to find the value of Y given you the formula, where another unknown ? And mathematics can’t do, not what scada
This reply was modified 8 years, 6 months ago by
manjey73.
manjey73ParticipantUnknown number is that you return to a channel after settlement.
Therefore, the formula cannot be an unknown number. It is either the calculation of other formulas (channel) or a known number.
manjey73ParticipantYou should start from here
There’s much more useful 🙂
Don’t know what is your native language, but I think online translator plus test will help understand how to work with those or other components of the system
manjey73Participant
manjey73ParticipantAnd you think I’m talking to you in plain English ? I just use online translate 🙂
Draw the picture in the scheme of what you should have, without adding what is not and as you did before. As the mention of Arduino in your case just confuses the situation.
I’ll try to do screenshots as it works for me with the Modbus RTU.
manjey73ParticipantYou are not using Arduino with RapidScada, and use some kind of analog output ?
Well, and send commands directly to the module output with Automatic Control ModulIn the presence of Hysteresis in the module you do not need any formula.
In manual mode you can force to work the module as you want ? Here’s the same commands send through an automatic how to activate or deactivate.
