manjey73ParticipantDownload and install the ChartsPro, , run the Web
Main menu-Plugins-Installed
Activate the ChartsPro, Click the Registration tab.To use ChartsPro go to Сonfiguration and specify it instead of simple Charts
December 2, 2019 at 11:17 am in reply to: about Rapid SCADA 5.7's Minimum archive data writing period #6136
manjey73Participant<Param name=”SendAllDataPer” value=”30″
ScadaCommSvcConfig.xml
Reduce this value in the Communicator configuration file and do not edit it in the WEB settings
manjey73ParticipantYes, the license is tied to the computer. For tests it was necessary to use reception of temporary keys.
This is how I usually test
manjey73ParticipantYou would screenshots have shown that and as you have broke a ?
manjey73ParticipantLike this limitation of the Protocol on 256 bytes when using standard reading functions
manjey73ParticipantDoes the device allow connection over multiple sockets or does it only work over one socket ? Disable the SOFTWARE it works with and try again.
manjey73ParticipantVersion : 5.2.0.1
manjey73ParticipantYou can, the module sends a letter not only to one recipient, but also to a group of recipients
manjey73ParticipantInput Channel
Channel 450, use formula – Yes, Val(450)
Output Channel
Channel 450, use formula – Yes, SetVal(450, Cmd)
Then you can use the data of this channel in other formulas
In principle, you can use the values of any input channels in other formulas, you should only remember that the value of the channel in the database is double
manjey73ParticipantOnly if another Scada has Modbus slave or is able to receive data from Databases to which Rapid Scada can export
August 7, 2019 at 2:49 pm in reply to: Dynamic text change to "error" if chanel value greater than specified value #5812
manjey73Participantns.fariz Yes, the scheme will look like numbers, except for the conditions that you specify. It works, I checked 🙂 But the status can be changed color, but I did not check
August 7, 2019 at 1:07 pm in reply to: Dynamic text change to "error" if chanel value greater than specified value #5805
manjey73Participantpublic double ToAscii(double channel, double min, double max)
string s = String.Format(“{0:F2}”, channel);
if (channel < min || channel > max) s = “Error”;
return ScadaUtils.EncodeAscii(s);
}353 Extra Channel – use formula ToAscii(Val(532), -1, 3.45)
Format – Text ASCII353 – The channel, which we will display as Dinamic text and two values for minimum and maximum
This reply was modified 6 years, 8 months ago by
manjey73.
August 7, 2019 at 12:57 pm in reply to: Dynamic text change to "error" if chanel value greater than specified value #5804
manjey73Participantpublic double ToASCII(double can)
string test = String.Format(“{0:F2}”, can);
if (can > 3.5) test = “Error”;
return ScadaUtils.EncodeAscii(test);
}Make an additional channel, put it in the Format – ASCII Text and use a similar formula. Specify the desired number of decimal places. It is better to add a couple of input variables for Min and Max to set in the formula… Output as Dynamic text.
August 7, 2019 at 11:45 am in reply to: Dynamic text change to "error" if chanel value greater than specified value #5803
manjey73ParticipantCan try a formula that any number will translate to text and if the number is less than or greater than the desired range, to make an inscription Error ?
That is, in fact, any correct number will be text and not the number itself.
Never tried that.
August 1, 2019 at 6:42 am in reply to: String dynamic text change according input channel value #5778
manjey73ParticipantLine 514, column 10:
See the file C:\SCADA\ScadaServer\Log\CalcEngine.cs with the source codeSee the file for this line and the error symbol
