Viewing 15 posts - 541 through 555 (of 923 total)
  • in reply to: Leading zeros #9976
    They can be displayed as ASCII text by applying time formatting. It seems that there are corresponding formulas in C#.
    Show your example how you display time on a mnemonic circuit
    • This reply was modified 4 years, 3 months ago by manjey73.
    in reply to: Date & Time Source and Display #9968
    The formula in the channel – DateTime.Now.ToOADate()
    Format channel is Date, Time or Date and Time
    in reply to: RTU500 AS 61850 SERVER #9942
    @Zeus We need to put up some kind of protection. It won’t save 100%, but still 🙂
    in reply to: Send command button – change register bit #9939
    public double SetBit(double n, int index, double setvalue)
    long nn = Convert.ToInt64(n);
    return setvalue > 0 ? nn | (1 << index) : nn & ~(1 << index);
    I do not know, is this what you need or not? Just writing a bit to a number. You need to add Formulas to the Reference Books
    in reply to: Auto Logon #9936
    $(document).ready(function () {
      $("#txtUsername").val("operator");
      $("#txtPassword").val("1234S");
    sleep(20000).then(() => { document.getElementById("btnLogin").click(); })
    function sleep(ms) {
      return new Promise(resolve => setTimeout(resolve, ms));
    Strange, I have double quotes and it works. Maybe the quotation marks code is from the Russian language, but it seems they should be the same.
    If you look in HEX format, the quote code is 0x22 everywhere
    in reply to: Auto Logon #9930
    Exactly, this forum is slightly spoiling some characters when inserting.
    in reply to: Auto Logon #9928
    The script is located in the file /scada/ScadaWeb/js/autologin.js where you specify your user and his password. It may be necessary to reboot the web to update the scripts in the browser, for example by Ctrl+F5
    in reply to: Step 11 fails #9868
    2. Copy the scripts from the daemons folder to /etc/init.d
    You probably tried to copy the boot scripts under a regular user and did not notice that there is no access, since /etc/init.d is not available to a regular user for writing.
    in reply to: Step 11 fails #9865
    Look at the code svc_install.sh Have you exactly copied the required files to the /etc/init.d folder?
    What is your system?
    in reply to: Auto Logon #9857
    https://yadi.sk/d/RZArYfy89mgjkw
    Strange, this plugin is not in the repository. Here is the link to the plugin that the author gave.
    Go to js and edit autologin.js my version is below with a delay of 20 seconds, which allows you to have time to change the user if necessary.
    $(“#txtUsername”).val(“operator”);
    $(“#txtPassword”).val(“1234S”);
    sleep(20000).then(() => { document.getElementById(“btnLogin”).click(); })
    in reply to: Auto Logon #9856
    Yes, it is possible
    in reply to: Evenet Log #9855
    Project/YourProject/Interface
    in reply to: Evenet Log #9853
    Place this xml in Project/Instance when you transfer data to the server and if there is no file there, then it is deleted from the main folder. This is true for all files that are copied from Instance to the corresponding folders.
    More precisely, Project/YuoProject/Interface
    in reply to: Evenet Log #9841
    Checked on Raspberry, Scada version 5.8.3 – works fine
    in reply to: Evenet Log #9838
    It seems they had to upgrade to a working version. I compared the files we tested on and the ones in the repository. There is a difference in the file EventsLog.xml . In what I have, the entry <Label>Alarms</Label>
    and <Label>Warnings</Label> is different
    there’s an s at the end. I also have a file Newtonsoft.Json.dll file in the bin folder is also an eventslog.js.map file in the plugins folder. the rest of the files have no differences
