Viewing 15 posts - 451 through 465 (of 923 total)
  • in reply to: Epoch time to Time date convert #12753
    in reply to: Epoch time to Time date convert #12751
    What is time in Epoch format ?
    Are you talking about Unix Time?
    • This reply was modified 2 years, 10 months ago by manjey73.
    in reply to: Installation 6.1.2 in Raspberry Pi #12747
    curl -sSL https://dot.net/v1/dotnet-install.sh | sudo bash /dev/stdin --channel LTS --runtime aspnetcore --install-dir /usr/share/dotnet/
    Try to install via a script from Microsoft
    Add a path as needed
    export PATH=”$PATH:/usr/share/dotnet”
    or a link as in the RapidScada installation documentation
    sudo ln -s /usr/share/dotnet/dotnet /usr/bin/dotnet
    Or for example like this
    For Low Byte
    Mask Input channel 118 – X = (ushort)Val(118) && 0xFF00
    Further – X || (ushort)Cmd
    For Older Byte
    Mask Input channel 118 – X = ((ushort)Val(118)>>8) && 0xFF
    Further – X || ((ushort)Cmd>>8)
    • This reply was modified 2 years, 11 months ago by manjey73.
    Well, bind the control command to the required channel that you are changing. To change the major and minor bytes, the write formulas will be different, just as you have made the formulas for obtaining the minor and major bytes different.
    2 One of the ways. You need to turn the CmdVal into a byte, Then, depending on whether it is older or younger, add it with the calculated byte of the second half and only then send the command. For example, if you change the highest byte. (Convert.Toint16(Cmd) >> 8) || Convert Uint16(Val(119)) where 119 is the value that you do not change and it is the lowest byte. Something like that
    I haven’t checked. Perhaps you can solve it differently or turn it into bytes beforehand, or apply a mask, and so on
    Get I 8 Byte Direct(Vol(118),0); Stat(118)
    in reply to: Structure of many instances #12531
    As for the support of discrete I/O, it can be supported through the gpiod library. At the moment I’m trying to make a driver for this library and RapidScada version 6. But as far as I understand, it either does not support analog inputs and outputs, or it depends on the equipment for which the assembly is made. I use Orange Pi+2E and judging by the code there is no support for analog inputs/outputs. Well, actually, such computers do not have galvanic isolation of inputs / outputs, all pins lead to the inputs of the SoC processor.
    in reply to: PC get slower #12376
    You can transfer archives to another disk and limit their storage time. Thereby freeing up space
    The administrator is not demanding of resources
    in reply to: modbus transfer string value #12365
    As far as I understand, you need to combine several registers into an array and specify a channel with the required data length. And in the Format to indicate that this channel is UNICODE or ASCII.
    I haven’t tried it myself yet, but it seems like this is how you need to work with strings
    in reply to: Rapidscada in Debian (on IoT2050) #12221
    It makes sense to use the Microsoft script installation command to understand whether it recognizes the processor or swears that there is no support for your processor.
    in reply to: Rapidscada in Debian (on IoT2050) #12220
    To install when using a script with Microsoft, you need to install curl
    apt-get install curl
    and give the command below, if Microsoft determines your processor and there is a dotnet for it, it should install the required packages.
    curl -sSL https://dot.net/v1/dotnet-install.sh | sudo bash /dev/stdin –channel LTS –runtime aspnetcore –install-dir /usr/share/dotnet/
    in reply to: Rapidscada in Debian (on IoT2050) #12219
    BogoMIPS : 400.00
    You have a strange processor.
    1. It may not be supported by Microsoft
    2. but it seems like dotnet is installed, maybe it is put in another folder on your system…
    in reply to: Rapidscada in Debian (on IoT2050) #12212
    The translator fussed 🙂
    Copied files do not mean that dotnet is installed and running.
    • This reply was modified 3 years, 1 month ago by manjey73.
    in reply to: Rapidscada in Debian (on IoT2050) #12211
    Show the output of the command
    cat /proc/cpuinfo
