Viewing 15 posts - 316 through 330 (of 923 total)
  • in reply to: Modbus display data format #15325
    Input scripts Cnl/1000 ?
    in reply to: Windows Scada project upload in Ubutu #15322
    /var/log/scada/ScadaAgent/Log
    Directly on the Linux machine along the logging installation path
    • This reply was modified 1 year, 7 months ago by manjey73.
    in reply to: Windows Scada project upload in Ubutu #15313
    service scadaserver6 start
    or
    systemctl start scadaserver6.service
    (restart, stop, status)
    (scadaagent6, scadacomm6, scadaweb6)
    the rest is by analogy
    Check for uwf on the remote Ubuntu machine. This is another firewall that can block your access
    in reply to: Windows Scada project upload in Ubutu #15308
    Flies separately, cutlets separately 🙂
    in reply to: Windows Scada project upload in Ubutu #15307
    No. .your pem key is used to access the remote server via ssh.
    To transfer the project from the Administrator, you need to open TCP port 10002 for ScadaAgent to work. Configure the firewall accordingly.
    The secret key and passwords in Scada are already internal protection methods so that third-party Scada Administrators cannot connect to your Scada Server and change the data.
    in reply to: Windows Scada project upload in Ubutu #15305
    The Ubuntu server can be remote with a real IP address (for example, on a VDS server) or connected to your server via VPN.
    And there is also an option when the Scada Agent connects via proxy mode. There are many connection options.
    in reply to: Windows Scada project upload in Ubutu #15300
    Yes, when you debug a project on a local PC, you can transfer it to a production Server by specifying its IP already. And the browser is already open on the remote PC, if the WEB server is located there.
    in reply to: Windows Scada project upload in Ubutu #15289
    In the deployment profile, specify where to transfer the project. Specify the IP of your Ubuntu server there instead of localhost
    in reply to: Problems with “Hello World” example. #15282
    Check if the ScadaAgent6 service is running
    in reply to: How best to proceed? #15280
    Here I used to import a function from the library for the driver of the 5th version of scada.
    By itself, the import probably will not be different for version 6, there are differences in the construction of the driver itself.
    https://github.com/Manjey73/OpnenKPs/blob/master/KpRpi3/KpRpi3/WiringPi.cs
    Oh, well, here’s an example for the Linux library.
    in reply to: How best to proceed? #15279
    C# allows you to use a dll in C if all the necessary functions are exported in the C library. Probably the best approach would be to write a driver for RS that will work with your C libraries and load data directly into the scada database.
    There are examples of how to use the C library in the RS driver. If necessary, I will give you links.
    in reply to: How best to proceed? #15271
    How do you receive data via the COM port?
    You have one Server database. Instances are required in the current version for remote Communicators.
    If you need different Server databases, you should have several projects, not one.
    in reply to: Seeking Ways to Give Back for RapidSCADA #15216
    One person cannot do everything at once. 🙂
    in reply to: Seeking Ways to Give Back for RapidSCADA #15214
    There are many newcomers here, but this does not prevent sharing :).
    Write what do you want to implement, a driver, a module, a plugin? they will always help with one or the other here. One problem, many people communicate through an online translator.
