The required logs are https://ibb.co/NC0PZ49
Paste the SQL scripts using the module configuration interface that is available in the Administrator app.
MikhailModeratorIn Rapid SCADA 5, edit WebSettings.xml and set DispEventCnt = 0.
MikhailModeratorIf you create several animated or not animated GIFs, you could switch them using Dynamic Picture component.
November 20, 2023 at 11:34 am in reply to: String dynamic text change according input channel value #13669
Screenshots of the settings would help to solve the issue.
MikhailModeratorTake the correct scripts from here.
All logs can be viewed in the Administrator apps. Click the drop down list and select Modules logs.
If you use Modbus communication protocol, you definitely need to know register addresses for polling the controller. Addresses are usually specified by a developer who programmed the PLC.
MikhailModeratorThank you for the screenshot.
Probably creating an animated GIF and using it in a dynamic picture component would be an efficient solution.November 17, 2023 at 9:08 am in reply to: Unable to communicate with Device 1 because connection is not established #13655
The received data is incorrect. Try to increase timeout and delay in the device properties.
Yes, it’s possible.
Please provide screenshots of the module settings and logs.
Please provide screenshots of your solution that help to understand the needs.
Try the HelloWorld project located in SCADA\ProjectSamples\HelloWorld
MikhailModeratorIs it HelloWorld project?
Do you login as “admin”?
Make sure that an object exists in the Objects table, and channel’s object is not empty. -
