Viewing 15 posts - 1,261 through 1,275 (of 6,225 total)
  • in reply to: Create Array template elements #13902
    An implementation depends on the driver. What communication protocol do you use?
    in reply to: Modbus Data Formula #13901
    Communication works well.
    What tag data is displayed on the device data page? Could you clarify the question?
    in reply to: Data Exporting #13897
    I suggest to create a separate trigger that exports only the channels that are not exported. It would be useful to create a new table in the DB for them. It can help to realize the cause of the problem.
    in reply to: Use logical judgment to calculate equipment working time #13896
    Good. This is a common task that many people ask.
    in reply to: How to use ModArcPostgreSql? #13893
    Channel formulas work only with current data. To calculate differences (e.g., power consumption), I suggest Elastic Report Plugin.
    in reply to: How to use ModArcPostgreSql? #13891
    Could you clarify your question?
    in reply to: Modbus Data Formula #13890
    Could you make a screenshot of the log?
    in reply to: Visual Devide Driver #13887
    I use sendcommand sending about 30 commands to virtual device per second and the base session will be suspended. The session will wait until the cmd is handeld.
    If commands require heavy processing, implement a queue to process them in background.
    I use the writcurdata method to send data to the server and persist the data to a dat file.
    To analyze the issue, you should use a debugger or log files.
    in reply to: Rapid SCADA IoT #13886
    Linux is preferable for a cloud server.
    in reply to: Rapid SCADA IoT #13885
    I suggest to deploy Rapid SCADA on a cloud server provided by Microsoft Azure, Google Cloud, Amazon, Digital Ocean or your local provider.
    in reply to: Visual Devide Driver #13880
    Hi Zeus,
    When I use the send command function to write a large amount of data to a virtual device, the session will be suspended.
    What amount of data you try to send using a command?
    When I use writing curdata to a virtual device, if the frequency is low, the data will become 0.
    Could you explain?
    in reply to: ExtTrendJP #13879
    in reply to: Modbus Data Formula #13878
    Check Communicator – Communication Lines – Your line – Line Stats – Line Log
    in reply to: Use logical judgment to calculate equipment working time #13873
    Something like (not tested)
    public double CountTime()
      return Val(101) > 0 ? Val() + 1 : Val();
    101 – channel that stores the machine state
    Then use this formula in a channel of the Calculated type: EveryMin(() => CountTime())
    in reply to: WAGO Pfc100 #13870
    Also, try specifying a byte order. For 16-bit float it could be 2301.
