MikhailModeratorFor sending SMS you need a GSM modem that supports AT command set, e.g. Cinterion MC55i http://www.smsco.it/tomcat/en/modem/cinterion_mc55i.jsp
The steps of configuring are:
1. Create an object, a communication line and a device (GSM modem) in the configuration database using SCADA-Administrator.
2. Import the above data into SCADA-Communicator and make sure that the connection with the modem is established.
3. Configure user interface.In case of configuring email notifications there is no physical devices, but you should also add a device of type Email into the configuration database.
Please ask for details during the process of configuration.
MikhailModeratorThere is an article detailed describes how to add devices to the system: http://rapidscada.org/connecting-devices-using-modbus-protocol/
In the article a Modbus device is added, but the ideas are the same.
MikhailModeratorThe general sequence of configuring:
1. Configure sending emails and SMS in manual mode.
2. Download Automatic Control Module, install it and add appropriate triggers.
MikhailModeratorI would like to let know the software here in Italy
That’s nice news 🙂
New version of web user interface is under active development. Definitely, it will be released in 2016.
MikhailModeratorMost likely you would update the whole SCADA-Communicator when KpSnmp update become ready.
Where are you need to display time?
MikhailModeratorIt is for Raspberry Pi only. Use command line.
Please start a new topic with you question about configuring in Understanding the Software subforum, please.
MikhailModeratorThe formula is
CnlStat==0||CnlStat==5?1:0
You must use one of the Calculated type of an input channel.
This reply was modified 10 years, 1 month ago by
MikhailModeratorOctetStrings are shown in Communicator in the new version of KpSnmp but they can’t be passed to SCADA-Server because SCADA-Server works with number values.
Reading Gauge32 issue has been added to tracker, it will be solved within 2 weeks. If you need it urgently please let me know.
MikhailModeratorThe new scheme engine is under construction. Don’t waste much time by improving the existing scheme project.
MikhailModeratorOpen ScadaSchemeWeb project properties, go to web tab and change viewSet as below
scheme/ScadaScheme.aspx?viewSet=0&view=1
MikhailModeratorPlease copy the result here and start a new topic for the new issue.
MikhailModeratorAlso check that Anonymous authentication is enabled:
http://origin-symwisedownload.symantec.com/library/BUSINESS/HOWTO83371/001-iis-default-web-site-authentication-setting.png
MikhailModeratorPlease open you Windows Features window again, expand Internet Information Services node and subnodes and send me a screenshot. I’m going to check what subitems are installed.
MikhailModeratorCould you post a screenshot of http://localhost/scada/scheme/ScadaSchemeSvc.svc ?
MikhailModeratorDoes it help?
