Viewing 15 posts - 4,861 through 4,875 (of 6,219 total)
  • in reply to: Scheme Symbols/IMG #3436
    OK 🙂
    in reply to: Source Code KpOpc.dll #3428
    Good job!
    Creating new versions, I will try to simplify the object model and configuration.
    Have you tested the driver on Linux?
    What are the next steps in your development?
    Would you share the driver with the community?
    When it is ready, I can add a link to http://demo.rapidscada.net/plugins/Store/Store.aspx
    in reply to: Display text variable from OPC #3427
    Try ASCII text (8 chars) or Unicode text (4 chars) formats. Minimum version of KpOpc.dll is 5.0.1.0
    in reply to: Rspberry Pi installation #3423
    I usually use 8GB cards.
    May you need to clean the card and install all from the beginning?
    Rapid SCADA itself is very small. To realize how much space are needed for Mono and Apache, you should check the appropriate docs.
    Is it possible to get plain image file of the working RPI SCADA?
    I don’t plan to create such image because Mono and other packages are updated often by their teams.
    What image of Raspbian do you use?
    in reply to: Source Code KpOpc.dll #3422
    If it targets to .NET Core or .NET Standard, it should not use DCOM.
    in reply to: ModDBExport #3418
    Thank you for the details.
    Set “Sending all device data” to 0 to switch off this feature.
    Also you can set “Period” to 0:00:20 in devices properties instead of a delay. In this case, devices will be polled more predictable, may be.
    in reply to: Source Code KpOpc.dll #3417
    I’ve never met such thread issues before. To be honest, I have no advice. You should to dig deeper ))
    What libraries do you use to work with OPC UA? Could you provide a link?
    in reply to: How to Use Dashboard plugins #3416
    The dashboard plugin works after installation and Registration for Chart Pro
    If you place several charts to a widget of a dashboard, Chart Pro is needed to show them. As I remember, the error message is not clear if Chart Pro is not installed.
    in reply to: ModDBExport #3411
    I saw is that if you put a time value lower than the total cycle of data adquisition for all devices, you get 2 records each time
    Could you explain this case more detailed and provide screenshots of your settings?
    in reply to: Data UpdateTime to Web Station #3410
    First of all, it is needed to analyze your system, specify work cases and then decide if the software should be optimized for the system.
    in reply to: Data UpdateTime to Web Station #3409
    A research is required to find a bottle neck. May be you need to develop your own plugin that access existing events. The web app support custom plugins.
    in reply to: How to Use Dashboard plugins #3407
    but the page showed “reCAPTCHA validation failed” while Geting a trial key.
    Can you use VPN to access the webpage?
    in reply to: How to Use Dashboard plugins #3406
    (1)what is the viewIDs in the file DashboardExample1.xml
    I had created a table “dsboard.tbl” with the ID “23”, and it can be viewed in the web.
    These are IDs of the views that contain channels of a widget. They are needed to access control.
    (2)How to use dashboard plugins?
    Use opens and watch them, like http://demo.rapidscada.net/plugins/Dashboard/Dashboard.aspx?key=allusers-DashboardDemo
    (3)When I used chart pro, the “Main Menu > Registration > Dashboard” can be seen. but the page showed “” while Geting a trial key
    Please provide a screenshot. You can put a link to an image hosting here.
    in reply to: ModDBExport #3401
    The time stamps are different. It means there were 2 inserts close by time for every channel. Communicator may send data twice, because it sends all the data again by the specified interval. You can change this interval in the settings of Communicator.
    in reply to: Data UpdateTime to Web Station #3400
    I suppose that 40 events per second is too much, and the software needs special performance optimization for your case. Why do you need an event for every change of a channel? You can export data to the external database without generating events.
