You should check a report example on Live Demo. But a year step is not supported, max. step is 1 month.
According to the log, your polling rate is about 1 second. It depends on network latency and controller speed.
So you need pulse length at least 2 seconds to detect it stable.
Can you explain the Timeout; Delay; Time ; Period; entries please
Please read this. If something is not clear in the article, ask.
Could you post a part of communication line log here to analyze? It’s in Line Stats
where do I set up the polling rate ?
It’s in Communicator – Communication line – Line Parameters – Request Sequence
MikhailModeratorWhen I try to add rights to the role, in the role tab – there is nothing in the interface Object.
You should press the Refresh button above the table to fill drop down lists of the cells.
Now I have an issue where no users can access the pages, even admin and guest
Please start a new topic to discuss this issue. Provide screenshots of the Roles and Users tables.
MikhailModeratorInteresting. Reloading the entire web server just to start new log…
Does the new approach stop reloading?
You need to specify a pulse length and polling rate. And make sure that polling rate is fast enough to detect a pulse.
Currently the MQTT driver doesn’t support string values. To support strings, update is required.
Also Rapid SCADA version 5 has a limitation of max. 8 Latin characters in tag. Is 8 characters enough for you?
What kind of string values do you need to read?
MikhailModeratorWhat’s the proper way to have a client showing the scada page 7×24?
It depends more on web server. For example, by default Windows IIS restarts application pool every certain period. It’s possible to disable restarting.
I haven’t heart that Apache also restarts something. Anyway, after web app restart, you will see break lines (——–) in ScadaWeb.log and then
2021-02-21 00:00:42 <opticalsensing><www-data><ACT> Initialize common web application data
How regular such text is in the log?
MikhailModeratorI disabled chart plotting and hide minute data export. So there should be one or more cause other than these 2.
Good idea.
I am going to make a program to monitor the cpu usage by mono, try if I can capture what cause the issue.
Probably there should be utilities to read CPU load, provide by SNMP and read by Rapid SCADA.
MikhailModeratorHis email is below this article.
i have write some kpdrivers moddrivers. how can i put it on website and sell it?
Are they ready for other users? I mean tested and contain manual?
Could you provide description of the modules?
It’s possible to publish them to the repository after some validating. Please create new topics to discuss the modules. It’s better, a topic for each module.
MikhailModerator🙂
MikhailModeratorOK
March 11, 2021 at 2:23 pm in reply to: Why ModDBExport Module is not publishing realtime or current data? #8489
MikhailModeratorSorry, I mean Generator.
I don’t see Channel in the list
You can type any channel number.
MikhailModeratorNote: Mono may work incorrectly if you open the web app by local browser and also open it remotely by IP address. It’s better to use Linux without GIU.
