mitesh
Participanthi joao,
I got the result. Thank you for your support joao.
mitesh
ParticipantNow i am able to login and getting all 4 channel data but i dont see any change in 5th channel. how to know the formula is working or not.
mitesh
Participanthello joao,
I am getting error in SCADA_Server.
ERROR: Line 505, column 56: error cs0103: The name ‘val’ does not exist in the current context
ERROR: Line 505, column 70: error cs0103: The name ‘val’ does not exist in the current context
ERROR: Line 505, column 83: error cs0103: The name ‘val’ does not exist in the current context
ERROR: Line 505, column 96: error cs0103: The name ‘val’ does not exist in the current contextafter this i am not able to login it show server is unavailable in the browser.
and also found the SCADA Communicator not communicating.
mitesh
ParticipantHello,
I have 4 input channels and i want to give all 4 channels mixing data to another new input channel.
Example: channel1 channel2 channel3 channel4 result of new channel
data –> 1 1 1 1 = 1and if any one of 4 channels data is zero i should get the result of new channel is zero.
please help me to come out from this problem.mitesh
ParticipantThank you mikhail. My problem has been solved.
December 12, 2017 at 3:59 pm in reply to: Error: The keyset is not defined in SCADA Administrator #2942mitesh
ParticipantHi Mikhail,
ScadaAdmin.err
2017-12-11 19:38:22 <MITUL-AMPTRONIC><Mitul><EXC> Error backing up the configuration database:
The keyset is not defined.2017-12-11 19:42:23 <MITUL-AMPTRONIC><Mitul><EXC> Error backing up the configuration database:
The keyset is not defined.2017-12-12 11:52:56 <MITUL-AMPTRONIC><Mitul><EXC> Error backing up the configuration database:
The keyset is not defined.2017-12-12 12:56:28 <MITUL-AMPTRONIC><Mitul><EXC> Error backing up the configuration database:
The keyset is not defined. -
