hethongscada62
ParticipantDear Mr. Mikhail,
My project that controls electricity parameters likes Voltage, current, power… was created. I is running. Now i want to get a consume energy per 1 minute, per 1 hour, per 1 day. Channels of the Minute and Hourly types were created. But i can not know which formula will be used. Could you help me to resolve this?
Thanks and best regards
Han Hoanghethongscada62
ParticipantDear Mr. Mikhail.
I am creating a new project “Smart ScadaFarm” on Raspberry Pi4. It is running but not unstable. Maybe all my devices are connecting to RaspberryPi4-server via Rs485-WiFi converter. Is that the cause of instability?.
Now i want that all these devices will be connected to Raspberry Pi4 via RS485-USB converter. Can they connect to Pi4? How will i configure?
Thanks and best regardshethongscada62
I want to notice that i created many projects in “Demo Project”.
https://ibb.co/CQLm2tP
The only one project that was changed password and the “secret key” Button was clicked can not upload configuration. The remain projects can upload normally.
Why, i don’t understand?
Pls help me.
My Demo project was repaired but not completely. I can login to web, every thing that seems is running OK except processing a upload configuration. I can not upload configuration. I checked an Instance Status that shows: “Unable to login – Invalid username or password”, “Unable to create session”.
What is wrong with Instance Default?
https://ibb.co/hm0Pp72
Could you show me again how i have to do?
ParticipantDear Mr.Mikhail,
My Demo project was working very very well. I can login to Web every where by Username: admin, password: 12345. That seems is unsafe so the password:12345 was changed by another but i can not upload. Returns to old password 12345, can not upload. And now i can not login to Web too. Some screenshots here:
https://ibb.co/tMYW4rp
https://ibb.co/VM1QyML
https://ibb.co/t3BPq6P
How will i do now, could you help me?
Han hoanghethongscada62
ParticipantDear Mr.Mikahil,
The rapid scada V_5.8.0_mono was installed on Raspberry Pi4. All modules are working that seems good:
https://ibb.co/CK3QFpt
Except a ScadaWeb. Noting in the ScadaWeb Log file. I can not see it on Web browser “Chrome”.
– How to open on Web browser “Chrome”
– How to open the Administrator?
ParticipantDear Mr.Kikhail,
– The timeouts were checked. They are 10000, not changed.
– Nothing changed in communication logic. Some devices were connected. But the configurations of devices on Version 5.8.0 are as the same as on Version 5.6.1.
Thanks a lothethongscada62
The Version 5.6 was updated to 5.8, but my Demo project on this new V.5.8. is working unstably. You can see some screenshot bellowing:
On Version 5.6.1: Working smoothly
https://ibb.co/bQnXQHx
On version 5.8.0: Server, seems, is running unstably:
https://ibb.co/Z6pW8wJ
https://ibb.co/Rb9ywCq
https://ibb.co/pXjM9qR
Why? Where is wrong?
My “Demo” project built on rapid scada version 5.6.1 is working very well. Now I want to update it to latest version 5.8. I’m afraid that my “Demo” project will fail when I update it myself. Because I have bad IT knowledge. I reckoned that updating from version 5.5 to 5.6 is easy while updating from version 5.6 to 5.8 is difficult for me, so could you please instruct me how to update from version 5.6 to 5.8 in more detail?
Thanks a lot
Hoang Xuan Hanhethongscada62
ParticipantDear Mr.manjjey73.
The rapid scada is great. It works perfectly now.
Thank you very much
ParticipantDear Mr.manjey73.
After Lunar New Year holidays i was tried to configure rapid scada to send commands to Relay board via scheme but i have not get the result. Could you help me how to create output channel? You can explain it by Russian. I can read it.
Thanks a lot
ParticipantDear manjey, every thing is good. I am able to control relay remotely via TCP. It is great.
Now i am going to configure a rapid scada to send commands from buton in the scheme. Can it? How to configure it?
Thanks a lot.
ParticipantDear manjey73,
Now i return to my idea: to send a command to relay board from Communicator via TCP/IP using RS485-Ethernet converter. Can the communicator do it? If it can so how to configure?
Thanks a lot
The problem was resolved. I can to control On-Off of relay now. The rapid Scada was great.
Thank you very much.
ParticipantHi manjey.
Stil can not. Where is wrong i can not find.
Very tried -
