manraj
ParticipantHi!.
When it comes to inserting values at the alarm threshold.there are 4 limits,Upper alarm limit,upper limit ,lower limit and lower alarm limit.Is there a way to insert a formula for that.Like Val(input channel)manraj
ParticipantHi!
Is there away to place formulas in the condition of a dynamic picture? because i tried putting Val(input channel) but it only read real number.
manraj
ParticipantI got it thank you very much.I will create the formulas and update here if there is any problem. Thank you!
manraj
Participant1. Do you mean i should add the constants to the Formulas table like this:
const double p2= output pressure (Output channel)
const double p1= input pressure(Input channel)
const double ρ=1000;
const double f= 0.05;
const double L= 12;
const double v= 3;
const double D= 0.1;Do i need to add on anything else at the start of the codes like “namespace” or “system” since its reads programming C#.Do you have any working example format of formulas so I can study how to insert formulas in the channel.
2.So I should have 2 input channels is it?.Input channel 1 should be the value is received from Modbus and channel 2 I should place in formulas in the SCADA administrator.?
Val(1)-(p*f*L*v^2)/2D–p multiply with f,l, and the square of v.Then divide 2*D
1 – is the number of the input channel for p1Thank you!
This reply was modified 9 years, 1 month ago by
manraj.
manraj
ParticipantI having trouble running my addition codes in SCADA,I am looking to take a value from the MODbus operator as an input value for this codes.
* C# Program to Get a Number and Display the Sum of the Digits
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;namespace Program
class Program
static void Main(string[] args)
int num, sum = 10,while (num != 0)
num = num / 10;
sum = sum + num;
}Please show me an example of a simple addition coding to test it in the scada configuration.I have a basic level C# coding only.
August 7, 2017 at 8:14 pm in reply to: Schematic picture not changing according to input channel #2466manraj
ParticipantHey there,
Well i tired re-downloading the Webstation app it but it did not work.But now my scheme plugin is version Version 5.1.0.2 and my Webstation is 5.0.2.1.What should I do next?
August 7, 2017 at 1:49 pm in reply to: Schematic picture not changing according to input channel #2464manraj
ParticipantMy scheme editor in this path C:\SCADA\ScadaSchemeEditor is version 5.1.0.2 and after restarting the server,cmmunicator and adminstration.My scheme in the http://localhost/Scada/plugins/Config/Plugins.aspx shows its version Version 5.1.0.1.I dont know whats wrong and I am having the same problem.
August 7, 2017 at 10:16 am in reply to: Schematic picture not changing according to input channel #2463manraj
ParticipantMy webstation is version 5.0.2.1 but my scheme version is 5.1.0.1. Where and how do i get the Scheme version updated.
manraj
ParticipantOkay thanks it did work but now what has happening is that the demo scheme has failed to load and after 3 seconds i get automatically logged out.
