Viewing 15 posts - 61 through 75 (of 981 total)
  • in reply to: Error Communication Failed #17850
    check the open ports in the system. the netstat command, if I’m not mistaken.
    in reply to: Error Communication Failed #17843
    show the text of the device log starting from the start of the line
    in reply to: Error Communication Failed #17841
    I can’t tell you who is changing the port, but the server, when sending to port 502, expects it to return to port 502.
    in reply to: Error Communication Failed #17839
    Destination Port: 50060
    Why would that be?
    in reply to: Error Communication Failed #17837
    copy the contents of the response from wireshark to modbus parser from the data block and find out. if there is an adequate response, then configure the firewall.
    in reply to: Event beep #17831
    However, this will require advanced Mimic components (paid), specifically ExtraMarkup from the components.
    in reply to: Event beep #17830
    You can create a circuit in the new Mimic editor and make the sound play cyclically while the page is open.
    in reply to: Error Communication Failed #17829
    Yes, if the address requires 0 for the device, this may be the reason. Another option is to send a broadcast address to the device – 254 or 255 in Modbus mode when it is connected to TCP. Such things should be specified in the device documentation.
    in reply to: Error Communication Failed #17826
    And start with one register, specifying in the settings to start with 0 or 1. Do you also have the exact device address = 1 ? Depending on the device, the device ID may be ignored in Modbus TCP mode, or it may have to correspond to some value.
    in reply to: Error Communication Failed #17824
    Disabling the firewall does not mean that packets will be skipped.
    in reply to: Error Communication Failed #17820
    and actually show the device configuration in the configuration database.
    in reply to: Error Communication Failed #17819
    show the log of a specific device. what data goes into it. is the device responding or just a timeout error?
    show the line and device settings.
    in reply to: Error Communication Failed #17817
    If you don’t see any bytes transmitted from the device in the log, then there is a problem with the connection.
    in reply to: Mobile resolution or view #17795
    As far as I know, no. I made a mnemonic specifically for the vertical version of a mobile device and created a second user specifically so that they could connect from a mobile device. Then he scored 🙂
    in reply to: Entering future data #17788
    – Will you have yesterday’s soup?
    – Yes, of course.
    – Then come back tomorrow. 🙂
    In order to write into the future, this future probably needs to be created. You can’t do this with scripts like that. It also doesn’t seem to be possible to read database data using scripts. But is it possible to rewrite the channel data all the time so that these values will be relevant tomorrow?
