Viewing 15 posts - 661 through 675 (of 981 total)
  • in reply to: Signal Relative ID to Fixed ID ? #9166
    Yes, this is a drawback of the Modbus driver and many others related to the tag generation code from the driver. I had to get away from this and look for a workaround by adding a mechanism to the code of my drivers to save the signal numbers that I want to see. As a result, I can disable or add variables without touching the signal numbering. For freely programmable devices, this is the first necessity. Yes, in other things, and for configurable ones, too.
    It is hoped that the developer will listen to this problem and make some changes, at least in the Modbus driver.
    in reply to: Shared variables #9158
    You pass the value of the channel itself in the command, and you need to pass Cmd or CmdVal, that is, the value of the command
    in reply to: Shared variables #9155
    SetVal(5050, Cmd)
    I’m confused, do you call your application Scada ?
    Existing Formulas
    • This reply was modified 5 years, 4 months ago by manjey73.
    in reply to: Shared variables #9109
    Add this value to the input channel and display it in a table or diagram
    in reply to: EncodeAscii #9070
    A formula in the reference list with an enumeration for example
    in reply to: ChartPro export data in hourly #9069
    Use the Elastic Report Plugin it can be set to the hourly version. But of course I would like to have such an opportunity in ChartPro
    in reply to: ChartPro export data in hourly #9068
    ChartPro takes data from the minute slice and is not yet able to show the chart and export it in hourly format
    in reply to: Redundancy #9035
    To fill the tanker, you must have reserved PLCs and I / O modules for critical tasks. This is not a Scada function. Think about security first. It is not necessary to burden the software with something that does not belong in it. I apologize for my English, I use an online translator
    in reply to: Redundancy #9024
    You can synchronize the time to achieve parallel polling by two Scada systems, by separating the polling time. I have already tested this on RS485 lines, it works. There may be collisions when restarting the server since the initial poll is performed immediately
    in reply to: Event Log #9019
    What Event Log are you talking about? built-in or optional from the repository ?
    in reply to: Redundancy #9011
    Use RapidGate it seems to be designed for this purpose. Or are you interested in hot swapping on the fly ?
    in reply to: Communicator will be stoped after Upload Configurations #9000
    @xdwokcn Do you happen to have a record of archived data in your drivers?
    in reply to: Rapid scada on beaglebine black #8993
    But to work with GPIO, you will most likely have to write a driver specifically for this PC.
    in reply to: Rapid scada on beaglebine black #8987
    What is Angstrom Linux based on?
    I very much doubt that it is possible to install Mono on this OS
    Debian for BeagleBoard
    If you install Debian, it is possible to start the system. At the expense of using GPIO, you need to look at what is implemented, if there is a libwiringPi assembly, then it is also possible
    • This reply was modified 5 years, 5 months ago by manjey73.
    in reply to: Communication is stopped without any infomation #8958
    Try to remove the check mark – Stay connected in the communication line settings.
