manjey73ParticipantIf you always need to pull out 2 bits each, then you can make one formula, just like getBit. If your pairs may differ, then you will need to make a formula and install it with your hands. Modify getBit into a different formula
public double GetTwoBit(double val, int n)
ulong ulVal = (ulong)val;
return (ulVal >> n) & 3ul;
}Here 3ul is the number 3 (00000011) and by shifting the bits by the right amount you make a logical one with two bits at once, and not one as in getBit. You can look at how much you need to shift in a calculator or even on a piece of paper.
This reply was modified 2 years, 3 months ago by
manjey73.
manjey73ParticipantPerhaps the username and password should still appear in the request, even if they are empty
manjey73ParticipantAnother option is to use the Auto-control Module and calculation channels for the values. But it seems to be superfluous here if Modbus is used
manjey73ParticipantHmm, sending different values from different buttons but to the same channel is a rare task. I remember there was such a problem, just related to the fact that it is impossible to specify a value when selecting “Send command immediately”
You need to make several calculation channels that will have their own formulas with different values to specify these channels in the buttons.
The Modbus device to which you are sending commands?
Add additional commands to the template that will lead to the same register and link them to the created channels.
manjey73ParticipantOnce you have indicated that the channel type is hex, write in the output formula of channel 111e and specify “Send command immediately” on the mnemonic and check.
If you need to send different values using different buttons, then you probably need to write a formula and use an enumeration.
manjey73ParticipantWhat do you enter when the command window opens and it works as it should?
manjey73ParticipantYes, it seems enough to specify the values in the output formula, but you have a value in hex format – 111e. You need to try, the output variable will also be double, you will probably need to convert it, for example, into a byte array, that is, use CmdData instead of Cmd
manjey73Participant@redass
When using the mnemonic circuit, there is a “Send command immediately” mode, by default the command sends a value of 0, which can be changed by the output formula of the channel at your discretion.
manjey73ParticipantI wrote examples when the scada script takes data from a file, for example. without creating a driver
manjey73Participantor if the code is very simple, try using it in scada scripts
manjey73Participantwrite a simple driver where your code, when going somewhere for the weather, will give you data as channel values.
manjey73ParticipantCnl != 255 ? (Cnl%256)/100 : doubleNaN
2.55 isn’t that after dividing by 100?
If the value from the device is 255, then you will receive
---well, or you still need to add status processing or perform it through status processing
manjey73ParticipantPLCs are to only Read and not Write data back to the Modbus devices.
Please translate, or draw a diagram of the interaction?
Do you have 3 PLCs but you can’t transfer data from others into them, but they can take data from Scada? – then use Modbus Slave
Do you have 3 PLCs and can you write Scada data in them? – then you need an Auto-Control Module
manjey73ParticipantUpdated the driver for version 6.
I threw the release on Git, so at least there is an understanding about the number of downloads.Creating templates is still done by hand, even though the graphic part from @JurasskPark is screwed on
manjey73ParticipantThe operating system has no effect on changing the keys. There are 3 conditions
1. Do not change the computer name
2. Do not change the Scada installation folder
3. Do not change the OS, for example, Windows was standing, but put Linux -
