zz
  • in reply to: ModDBExport issue #2096
    zz
    2017-04-12 14:18:01.1970000
    2017-04-12 14:17:40.5530000
    2017-04-12 14:17:30.6030000
    2017-04-12 14:17:30.5930000
    2017-04-12 14:17:30.5800000
    2017-04-12 14:17:30.5700000
    2017-04-12 14:17:01.2230000
    2017-04-12 14:16:30.4770000
    2017-04-12 14:16:30.4670000
    2017-04-12 14:16:30.4430000
    2017-04-12 14:16:30.4330000
    2017-04-12 14:16:01.5600000
    2017-04-12 14:16:01.0530000
    2017-04-12 14:15:30.3300000
    2017-04-12 14:15:30.3200000
    2017-04-12 14:15:30.3100000
    2017-04-12 14:15:30.3000000
    2017-04-12 14:15:01.2300000
    2017-04-12 14:14:30.3300000
    2017-04-12 14:14:30.3200000
    2017-04-12 14:14:30.0830000
    2017-04-12 14:14:30.0730000
    2017-04-12 14:14:20.5570000
    2017-04-12 14:14:01.1970000
    2017-04-12 14:13:29.9030000
    2017-04-12 14:13:29.8900000
    2017-04-12 14:13:29.8800000
    2017-04-12 14:13:29.8700000
    2017-04-12 14:13:01.0130000
    2017-04-12 14:12:40.5600000
    2017-04-12 14:12:29.7670000
    2017-04-12 14:12:29.7530000
    2017-04-12 14:12:29.7430000
    2017-04-12 14:12:29.7330000
    2017-04-12 14:12:01.2000000
    2017-04-12 14:11:29.6300000
    2017-04-12 14:11:29.6170000
    2017-04-12 14:11:29.6070000
    2017-04-12 14:11:29.5970000
    2017-04-12 14:11:01.5600000
    2017-04-12 14:11:01.0970000
    2017-04-12 14:10:29.4830000
    2017-04-12 14:10:29.4730000
    2017-04-12 14:10:29.4600000
    2017-04-12 14:10:29.4500000
    2017-04-12 14:10:01.2300000
    2017-04-12 14:09:29.2930000
    2017-04-12 14:09:29.2830000
    2017-04-12 14:09:29.2700000
    2017-04-12 14:09:29.2600000
    2017-04-12 14:09:01.2230000
    2017-04-12 14:08:55.5530000
    2017-04-12 14:08:29.0970000
    2017-04-12 14:08:29.0870000
    2017-04-12 14:08:29.0770000
    2017-04-12 14:08:29.0670000
    2017-04-12 14:08:01.2230000
    2017-04-12 14:07:28.9600000
    2017-04-12 14:07:28.9500000
    2017-04-12 14:07:28.9400000
    2017-04-12 14:07:28.9270000
    2017-04-12 14:07:01.2230000
    2017-04-12 14:06:50.6000000
    SCADA-Communicator
    Started : 10/04/2017 16:42:49
    Execution time : 1.22:19:55
    Version : 5.0.0.1
    SCADA-Server : version 5.0, authentication is successful
    Active Communication Lines
    1. Line 7 “ModbusRTU-TCP4001” : running
    in reply to: ModDBExport issue #2094
    zz
    Hello
    settings are:
    time: 00:00:00
    period: 00:00:05
    timeout 1000
    delay 200
    there is only one modbus address,
    in reply to: ModDBExport issue #2087
    zz
    Hello Mikhail,
    I use modbus RTU via TCP,it works correclty and I see correct data
    I would like to export only values that are read every 1 minute but see them online every 5 seconds as currect value.
    Also I see in database double data on same time, only miliseconds between writes to database. This is very strange behaviour, because I dont know what is the trigger to write to database doubled data in same time
    4 2017-04-09 19:59:34.1600000 705 3265996 1
    5 2017-04-09 19:59:34.1600000 704 510,493438720703 1
    6 2017-04-09 19:59:34.1600000 703 107,399993896484 1
    7 2017-04-09 19:59:34.1600000 702 24,3499984741211 1
    8 2017-04-09 19:59:34.1600000 701 16 1
    9 2017-04-09 19:59:34.1370000 705 3265996 1
    10 2017-04-09 19:59:34.1370000 704 510,493438720703 1
    11 2017-04-09 19:59:34.1370000 703 107,399993896484 1
    12 2017-04-09 19:59:34.1370000 702 24,3499984741211 1
    13 2017-04-09 19:59:34.1370000 701 16 1
    Can you propose SQL script to resolve my problem ?
