subairi
Participantsubairi
Participantmy folder “config” at C:\SCADA\ScadaWebConfig not found
is this true?subairi
ParticipantScreenshot from my PC: Control Panel -> Programs -> Turn Windows features on or off
https://postimg.org/image/w0zn9h66n/
screenshot error web config
https://postimg.org/image/5revt0evp/<img src=”https://postimg.org/image/5revt0evp/” alt=”error web config” />
subairi
Participantthis is log setup
Start Rapid SCADA 4.5.7 installation 16/09/2016 3:43:09
Create directory C:\SCADA\
Create directory C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SCADA\Check Microsoft SQL Server Compact 3.5
Install SCADA-Administrator:
Unzip files from ScadaAdmin.zip
Create shortcut SCADA-Administrator
SCADA-Administrator installation has completed successfullyInstall SCADA-Server:
Unzip files from ScadaServer.zip
Create shortcut SCADA-Server
Install service ScadaServerService
SCADA-Server installation has completed successfullyInstall SCADA-Communicator:
Unzip files from ScadaComm.zip
Create shortcut SCADA-Communicator
Install service ScadaCommService
SCADA-Communicator installation has completed successfullyCheck the configuration of Internet Information Services (IIS)
Go to
and make sure that WCF Services -> HTTP Activation feature is installed for .NET Framework 4+
Before SCADA-Web installation it’s required to install the following Internet Information Services (IIS) components:
Static Content
For this purpose go to
Control Panel -> Programs -> Turn Windows features on or offInstall SCADA-Web Configurator:
Unzip files from ScadaWebConfig.zip
Create shortcut SCADA-Web Configurator
SCADA-Web Configurator installation has completed successfullyInstall SCADA-Table Editor:
Unzip files from ScadaTableEditor.zip
Create shortcut SCADA-Table Editor
SCADA-Table Editor installation has completed successfullyInstall SCADA-Scheme Editor:
Unzip files from ScadaSchemeEditor.zip
Create shortcut SCADA-Scheme Editor
SCADA-Scheme Editor installation has completed successfullyInstallation has completed with errors 16/09/2016 3:43:11
subairi
ParticipantI’m already working according to the instructions, but still error.
where do I screenshot error?
