Michal Dziczkowski
Participant> 1. Covert DB itself.
> 2. Develop a utility that will “pass the configuration database to
> server app”. It means convert SQLite to *.dat files used by the
> Rapid SCADA apps.ad. 1: I think that there online some converters with could do that
ad 2: wouldn’t be easier to implement a direct support and actions on the database instead of doing so many additional (and mostly unnessecary) steps with would make the usage more dissicult?I suggest that instead of *.dat use the extension *.db because not every software can correctly reorganize, read and write it.
About the app server… have you heard about the GO language? there is quite easy to create in it a system independant (it will be able to get compiled on Windows, Linux and Apple OS) server with could make the data accessable
Michal Dziczkowski
Participantwouldn’t it be easier to do RapidScada more modular? this would for sure simplify the develpoment process and future extending of it
Michal Dziczkowski
Participantthat’s true, but developing one would require time and resources (like for example programmers, money, etc.) and this would delay much the development process.
If I may, then I would propose to convert the database files to SQLite and till the editor get’s ready, allow to use the SQLite database managemnt and edition software.
My question is, who would develop such editior about You wrote and would it be a OpenSource, or other free kind license or a commercial product. If commercial then how much would it cost.
Please take it into attention that not every one can afford themself to buy a commercial license, so this why a free license would be the best choice here.
Michal Dziczkowski
Participant> Anyway it’s hard to configure the system by standard DB editor without a specialized GUI editor.
and
> Convert the configuration database to SQLite and develop an editor for it
there is no need to develop a special *.db editor since such ones are already avaliable, like for example: https://github.com/lazierthanthou/sqlite-manager. It has even a Firefox plugin
Michal Dziczkowski
Participantwhat do You think, with one from the two options you gave would be more possible and easier to do ?
Michal Dziczkowski
Participant> All the existing manuals are published
where exactly? I don’t see any link to it on the rapidscada.org website
> If you edit *.tbl by Table editor, all parameters are accessible via GUI.
How can I access it, since I don’t see it (neither the SchemeEditor) neighter in the download section of the page, nor in the downloaded file
> If you edit them manually, see ServerRoom.tbl as an example.
The params aren’t documented in it
> If you described it, I could generate an idea how to solve it in optimal way
How about replacing the Microsoft SQL Server Compact (*.sdf) format with more universal one, like for example sqlite (*.db)?
Michal Dziczkowski
Participantlet me put it more simple:
http://localhost:8084/scada works and nothing else (else things throw errors)
Michal Dziczkowski
ParticipantGoogle isn’t the best tool for translation (not very exact) but it’s good if some one don’t know the source language
Michal Dziczkowski
ParticipantI had uninstalled and re-installed mono, xsp4 RapidScada. Only the part with /scada started to work and the remaining ones still throw errors
Michal Dziczkowski
Participantmono: 3.2.8+dfsg-4ubuntu4
mono-xsp4: 3.8-2.1Michal Dziczkowski
Participant- dabian.webapp:
<apps> <web-application> <name>scada</name> <vpath>/scada</vpath> <path>/etc/scada/ScadaWeb</path> </web-application> </apps> - mono-xsp4:
# Defaults for mono-xsp4, official version # sourced by /etc/init.d/mono-xsp4 # Should we start it? start_boot=true # User and group by default user=www-data group=www-data # Default port port=8084 address=0.0.0.0 # Directory for config files config_files=/etc/xsp4 - xsp4/conf.d/scada/10_scada:
This is the configuration file for the scada virtualhost path = /etc/scada/ScadaWeb alias = /scada
Michal Dziczkowski
Participanttryed. The result was:
System.ArgumentException Directory does not exists Parameter name: value Description: HTTP 400.Error processing request. Details: Non-web exception. Exception origin (name of application or object): System. Exception stack trace: at System.IO.FileSystemWatcher.set_Path (System.String value) [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.IO.FileSystemWatcher:set_Path (string) at System.Web.HttpRuntime.SetupOfflineWatch () [0x00000] in <filename unknown>:0 at System.Web.HttpRuntime.Process (System.Web.HttpWorkerRequest req) [0x00000] in <filename unknown>:0 at System.Web.HttpRuntime.RealProcessRequest (System.Object o) [0x00000] in <filename unknown>:0 at System.Web.HttpRuntime.ProcessRequest (System.Web.HttpWorkerRequest wr) [0x00000] in <filename unknown>:0 at Mono.WebServer.MonoWorkerRequest.ProcessRequest () [0x00000] in <filename unknown>:0Michal Dziczkowski
ParticipantI have downloaded the Linux version and I wanted to test it on my Ubuntu 14.04
The login link returned:
System.Web.HttpException The resource cannot be found. Description: HTTP 404.The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly. Details: Requested URL: /scada/login.aspx Exception stack trace: at System.Web.Compilation.BuildManager.AssertVirtualPathExists (System.Web.VirtualPath virtualPath) [0x00000] in <filename unknown>:0 at System.Web.Compilation.BuildManager.Build (System.Web.VirtualPath vp) [0x00000] in <filename unknown>:0 at System.Web.Compilation.BuildManager.GetCompiledType (System.Web.VirtualPath virtualPath) [0x00000] in <filename unknown>:0 at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath (System.Web.VirtualPath virtualPath, System.Type requiredBaseType) [0x00000] in <filename unknown>:0 at System.Web.UI.PageParser.GetCompiledPageInstance (System.String virtualPath, System.String inputFile, System.Web.HttpContext context) [0x00000] in <filename unknown>:0 at System.Web.UI.PageHandlerFactory.GetHandler (System.Web.HttpContext context, System.String requestType, System.String url, System.String path) [0x00000] in <filename unknown>:0 at System.Web.HttpApplication.GetHandler (System.Web.HttpContext context, System.String url, Boolean ignoreContextHandler) [0x00000] in <filename unknown>:0 at System.Web.HttpApplication.GetHandler (System.Web.HttpContext context, System.String url) [0x00000] in <filename unknown>:0 at System.Web.HttpApplication+<Pipeline>c__Iterator1.MoveNext () [0x00000] in <filename unknown>:0 - dabian.webapp:
