JonatasP
ParticipantFirst of all, let’s make sure about the reason. Please write about the result after changing localization.
Changed language using:
sudo dpkg-reconfigure locales
from pt_BR.UTF-8 UTF-8
to en_US.UTF-8 UTF-8
And now i can sucesfull login in rapid scada.JonatasP
ParticipantThere is no possibility to make an adjustment in the software to fix it?
I will switch location and language back to english, in the meantime.JonatasP
ParticipantThe operational system is armbian(in english), but the locations and language are portuguese-brazil -charset UTF8.
What i can do to solve the problem?JonatasP
ParticipantThe SO is installed in internal memory of Orange Pi.
JonatasP
ParticipantIn Linux the log is located in “/ etc / scada / Scada Server / log / ScadaServer / Svc.log” right?
The content is as follows:2016-05-05 08:51:04 <orangepiplus2><root><ACT> ScadaServerService 4.5.0.5 is started 2016-05-05 08:51:05 <orangepiplus2><root><ACT> Check the existence of the data directories is completed successfully 2016-05-05 08:51:05 <orangepiplus2><root><ACT> Check the existence of the configuration database files is completed successfully 2016-05-05 08:51:06 <orangepiplus2><root><ACT> Input channels are read from the configuration database. Active channel count: 14 2016-05-05 08:51:06 <orangepiplus2><root><ACT> Ouput channels are read from the configuration database 2016-05-05 08:51:06 <orangepiplus2><root><ACT> Users are read from the configuration database 2016-05-05 08:51:06 <orangepiplus2><root><ACT> Formulas are read from the configuration database 2016-05-05 08:51:08 <orangepiplus2><root><ERR> Error compiling the source code of the formulas: Line 79, column 31: error CS0589: Internal compiler error during parsingSystem.FormatException: Input string was not in the correct format Line 0, column 0: error : at System.Double.Parse (System.String s, NumberStyles style, IFormatProvider provider) [0x00000] in <filename unknown>:0 Line 0, column 0: error : at Mono.CSharp.Tokenizer.adjust_real (TypeCode t, Location loc) [0x00000] in <filename unknown>:0 Line 0, column 0: error : at Mono.CSharp.Tokenizer.is_number (Int32 c, Boolean dotLead) [0x00000] in <filename unknown>:0 Line 0, column 0: error : at Mono.CSharp.Tokenizer.xtoken () [0x00000] in <filename unknown>:0 Line 0, column 0: error : at Mono.CSharp.Tokenizer.token () [0x00000] in <filename unknown>:0 Line 0, column 0: error : at Mono.CSharp.CSharpParser.yyparse (yyInput yyLex) [0x00000] in <filename unknown>:0 Line 0, column 0: error : at Mono.CSharp.CSharpParser.parse () [0x00000] in <filename unknown>:0 See the file /etc/scada/ScadaServer/Log/CalcEngine.cs with the source code 2016-05-05 08:51:09 <orangepiplus2><root><ERR> Normal program execution is impossible. -
