Controlling a **PowerFlex 525** directly from Node-RED over **EtherNet/IP** is possible, but it depends on the available EtherNet/IP nodes and their support for the drive’s CIP objects and assemblies. If the existing nodes don’t fully support the required services, you may need a custom implementation or an EtherNet/IP library. While Allen-Bradley PLC systems are the standard approach for integrating PowerFlex drives, a direct Node-RED solution can be a cost-effective alternative if the communication is configured correctly. Sharing your current setup and test results will make it easier for others to help troubleshoot.
