liuhb2
  • in reply to: OPC DA to OPC UA Server Question Communicator #17612
    liuhb2
    thank you,I will try it later。
    in reply to: OPC DA to OPC UA Server Question Communicator #17606
    liuhb2
    After installing “OPC Core Components Redistributable (x86) 3.00.108.msi” and “windowsdesktop-runtime-8.0.22-win-x86.exe”, when starting RapidAdmin, I receive a prompt indicating that the x64-bit .NET runtime environment needs to be installed. Is it because RapidAdmin is x64-bit, so the 64-bit library is required? Is there a way to configure it to use the x86 library? Or are there any other solutions? Thank you very much.
    in reply to: OPC DA to OPC UA Server Question Communicator #17601
    liuhb2
    While testing the conversion from OPC DA to OPC UA, I encountered an issue where an error occurs if I do not install the OPC Core Components Redistributable (x64) 3.00.108. However, my production environment only supports 32-bit systems. So, how can I configure Rapid SCADA to use the runtime of OPC Core Components Redistributable (x86) 3.00.108 instead? Error code is 0x80040154
