Gabor
Viewing 3 posts - 16 through 18 (of 18 total)
  • in reply to: Error Communication Failed #17821
    Gabor
    No,it looks like it does not respond at all (sending data continuously but 0 response). I started all from zero as shown in the modbus video and all worked with the simulator, however not worked on a real device. Will attach files in the afternoon as I am currently not near the setup.. Thanks in advance
    in reply to: Error Communication Failed #17818
    Gabor
    Thank you for your reply. This is what I am thinking too.. Unfortunately can’t figure it out what the problem can be. Changed the IP address from localhost to the device IP in the project file (in 2 places), is there anything else to do? Target Device responses to ping and also tested port 502 with telnet command. Direct connection with lan cable, firewall off.
    in reply to: Scada webstation not getting open #17568
    Gabor
    Hello! I had issue installing Rapid Scada (came with error) on Windows7 and make the Webstation to work, when I realized one of the comment said Win7 is no longer supporter (however rapidscada.net stated win7 is supported with SP1, but now I see its for the old documentation) So a bit confusing,as I am new to Scada.
    Also noticed Rapid Scada is no longer Free?
    I mean if we want to make working projects with tags (sensor input reading,plc,visualization,etc) it is not free anymore.. Just wanted to confirm.
    Thank you
