123
ParticipantWhy is no one responding to me?
123
ParticipantHello, I downloaded the compression package you provided. I am using a computer with Windows 10 Professional. When I run SetCulture.exe as an administrator, SetCulture.exe flashes by and closes immediately, making it impossible to set the language.
Additionally, I placed SetCulture.exe, ScadaData.dll, and Log.dll in the directory C:\Program Files\SCADA\ScadaSchemeEditor. When I run SetCulture.exe as an administrator, it still flashes by and closes immediately.
123
ParticipantCurrently, the version of your ScadaSchemeEditor.exe only goes up to 5.3.1.2, so I need this tool. Could you please provide me with one?
123
ParticipantHello, why hasn’t anyone responded to my question yet?
123
ParticipantI can only see the download for version 6.4.3 on the website. How come the downloads for historical versions like 6.4.0, 6.4.1, and 6.4.2 are not visible?
123
ParticipantSuppose I modify the graphical interface of the source code based on Rapid SCADA, make changes to the command display interface code, and even add new code for communication acquisition protocols. Would this be considered a derivative product?
If it is considered a derivative product, am I allowed to modify the names and icons in Image 1 and Image 2 below? I have annotated the modified parts in the images.
Image 1 URL:https://imgur.com/a/8RnjW9e
Image 2 URL:https://imgur.com/a/yfuY8xSIf the above images fail to load, you can download them.
123
ParticipantIn short, according to Apache License 2.0 you can create a derived product with a new name, but you have to explicitly provide information about the original product.
Hello, please respond to my following questions separately?
1.Based on your response, am I allowed to change the product name and the product name?
2.Regarding providing information about the original product, can I credit the product’s source in the “About” section of the Main Menu? Does this count as providing information about the original product? If not, please provide a concrete example.
123
ParticipantOn the web interface, clicking the Main Menu reveals options for Reports, Plugins, and About. According to the Apache License 2.0, am I allowed to hide the Plugins and About sections?
123
ParticipantSo, does that mean I can modify everything, including trademarks and product names?
123
ParticipantIf I’m using the template with dataBlock=”HoldingRegisters”, as described below,how can I configure it to use function code 0x03 for reading and function code 0x07 for writing?
<DeviceTemplate>
<Options>
<ZeroAddr>false</ZeroAddr>
<DecAddr>true</DecAddr>
<DefByteOrder2 />
<DefByteOrder4 />
<DefByteOrder8 />
</Options>
<ElemGroups>
<ElemGroup active=”true” dataBlock=”HoldingRegisters” address=”0″ name=”test”>
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test1″ name=”test1″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test2″ name=”test2″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test3″ name=”test3″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test4″ name=”test4″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test5″ name=”test5″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test6″ name=”test6″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test7″ name=”test7″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test8″ name=”test8″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test9″ name=”test9″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test10″ name=”test10″ />
<Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”test11″ name=”test11″ />
</ElemGroup>
</ElemGroups>
<Cmds>
<Cmd dataBlock=”Custom” funcCode=”7″ cmdNum=”1″ cmdCode=”Custom” name=”Custom” />
</Cmds>
</DeviceTemplate>123
ParticipantI tried using a custom function code, as described in the example below. The function I sent was for reading, and the function code used was 0x00. Could you provide a detailed example of how to use custom function codes?
1.
<ElemGroup active=”true” dataBlock=”Custom” address=”0″ name=”定值”>
<Elem type=”ushort” readOnly=”false” isBitMask=”true” tagCode=”test1″ name=”test1″ />
</ElemGroup>
</ElemGroups>
<Cmds>
<Cmd dataBlock=”Custom” funcCode=”7″ cmdNum=”0″ cmdCode=”Custom” name=”Custom” />
</Cmds>123
ParticipantThe version I’m using is rapidscada_6.4.1_windows_en.
123
ParticipantThe URL in the first point below contains images of the request and response. If they cannot be viewed directly, they can be downloaded. After opening the new view and once the data loading is complete, the functionality can be properly accessed and used without any issues.
So if this issue occurs, should we address it or simply ignore it?
123
ParticipantBoth point 1 and point 2 below are image links. If the images do not load when you visit the website, you can download them directly.
1.https://imgur.com/a/hG50y57
2.https://imgur.com/a/hG50y57-
This reply was modified 1 year ago by
123
ParticipantThe comment section does not support image pasting, therefore I had to resort to copying and pasting the error text.
