qwertyqwq
  • in reply to: Installation on Raspberry Pi #17354
    qwertyqwq
    After doing some research, I realized that my ASP.NET Core Runtime 8.0.x installation was not working at all. By following up on some of the error messages, I eventually managed to solve the problem. Below, I’m sharing the command sequence that successfully worked for me (on Raspberry Pi 64-bit):
    sudo apt-get install -y gpg
    wget -O – https://packages.microsoft.com/keys/microsoft.asc | gpg –dearmor -o microsoft.asc.gpg
    sudo mv microsoft.asc.gpg /etc/apt/trusted.gpg.d/
    wget https://packages.microsoft.com/config/ubuntu/22.04/prod.list
    sudo mv prod.list /etc/apt/sources.list.d/microsoft-prod.list
    sudo chown root:root /etc/apt/trusted.gpg.d/microsoft.asc.gpg
    sudo chown root:root /etc/apt/sources.list.d/microsoft-prod.list
    sudo apt-get update && \
    sudo apt-get install -y dotnet-sdk-8.0
    Since this was almost my first time using Linux, the process was quite exhausting for me, but I’m glad that I finally found a command sequence that works. Anyone who is a beginner like me and trying to install RapidSCADA on a Raspberry Pi can use these commands.
    Thank you for your attention.
    in reply to: Virtual Machine integration #17351
    qwertyqwq
    in reply to: Closed serial port #16925
    qwertyqwq
    Im using 6.2.1.3 version
    in reply to: Closed serial port #16924
    qwertyqwq
    Yes, thank you, I solved the previous issue. I added the passwords I had set for Communicator and WebStation to the Users section and granted all of them Administrator privileges.
    However, I have another question. Right now, I am unable to upload because I changed the Username and Password in the Agent connection. I have also added these new Username and Password values to the Users section, but I still cannot upload. Could you please guide me?
    in reply to: Closed serial port #16920
    qwertyqwq
    Thank you for your response.
    I’m absolutely sure that no other software is using the COM port.
    I’ve created a new project many times. At the beginning, when I set up the serial port, I can see the data flow working correctly on the administrator application.
    However, as soon as I configure the Channels and upload the code, I notice that COM3 is closed, but it does not reopen again.
    I’m sharing the log and text record from Communicator here.
    This part is after I uploaded the software.
    Even so, in the Line State and Line Log tabs, nothing changes or new entries appear after the upload.
    The message saying that the COM port is closed always remains as the last message.
    This is SCADACOMM.log
    2025-08-26 15:30:20 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ACT] Start logic processing
    2025-08-26 15:30:20 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ACT] Driver DrvCnlBasic 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvCnlBasic.Logic.dll
    2025-08-26 15:30:20 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvDsScadaServer.Logic.dll
    2025-08-26 15:30:20 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ACT] Driver DrvModbus 6.0.0.4 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvModbus.Logic.dll
    2025-08-26 15:30:20 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ACT] Data source ScadaServer initialized successfully
    2025-08-26 15:30:20 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ACT] Data source ScadaServer: Receive the configuration database
    2025-08-26 15:30:23 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ERR] Data source ScadaServer: Error checking server connection:
    Invalid username or password
    2025-08-26 15:30:23 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ERR] Unable to start communication lines because the configuration database is not received
    2025-08-26 15:30:30 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ACT] Data source ScadaServer: Receive the configuration database
    2025-08-26 15:30:33 [DESKTOP-M2JC1C1][DESKTOP-M2JC1C1$][ERR] Data source ScadaServer: Error checking server connection:
    SCADACOMM.txt
    Communicator
    Started : 26/08/2025 15:30:20
    Execution time : 00:00:46
    Status : Error
    Version : 6.2.0.1
    Data Sources (1)
    [ScadaServer] Server Data Source : Ready
    Server Data Source
    Connection : Not Used
    Current data queue : 0 of 1000, skipped 0
    Historical data queue : 0 of 1000, skipped 0
    Event queue : 0 of 1000, skipped 0
    Communication Lines (0)
    No lines
    in reply to: Closed serial port #16915
    qwertyqwq
    I am using Windows 10 Pro on my computer. For the physical interface, I am using a classic USB-RS485 converter.
    rs485-usb converter
    • This reply was modified 1 year, 2 months ago by qwertyqwq.
