Viewing 15 posts - 6,031 through 6,045 (of 6,387 total)
  • in reply to: ScadaScheme can't run #963
    Probably it’s possible to make it work, but I think it will take too much time.
    May be you have a possibility to install SCADA-Web application to a different machine? It can operate separately from back end applications.
    in reply to: Calculated Real working unreliable #962
    Cnl/( Val(768)*100 + (1-Val(768)) )
    you can change to
    Cnl / (Val(768)>0?100:1)
    in reply to: Calculated Real working unreliable #961
    If you receive data from Communicator in the channel 808, you have to turn it to Real channel type.
    If the channel type is Real, the formula is calculated only when SCADA-Server receives data from SCADA-Communicator.
    So you need to create an additional channel of Calculated Real type that will be quickly response to changes of the channel 768, and it depends on 768 and 808 channels.
    in reply to: Automatic Control Module (ACM) Licenses #959
    If i need to buy a new license for every client, can i charge extra for it(have profit over the license value)? Or the client itself need to buy the license from RapidSCada.org?
    Are you planning to offer Software as a Service for you clients? I think we should discuss these in details to create the best offer. Could you describe your vision by email?
    in reply to: Automatic Control Module (ACM) Licenses #958
    Could you explain what ACM is, please?
    For now the difference between Home and Business types of licenses is the price only. The reason is that the home automation should cheaper in compare with business purposes in accordance with the customer capabilities.
    The existing licenses apply to a one server without limit of connections. Thereby, you need one license for each client.
    in reply to: ScadaScheme can't run #954
    The one message is not translated…
    Please open http://localhost/scada/scheme/ScadaSchemeSvc.svc and tell me what you see?
    May be in IIS 6 you need to make some configuration of web services processing.
    Does Insufficient rights error still occur?
    P.S. The new web application is under construction. It will be free of those issues
    in reply to: Scada-Admin don't open. #950
    Just install MSSQL Compact from the prerequisites.
    You have to execute both:
    SSCERuntime_x86-ENU.msi
    SSCERuntime_x64-ENU.msi
    in reply to: String tag communication in rapid scada #948
    If you are talking about Modbus protocol, command must be converted to the array of bytes. Using formulas of output channels you can send any array of bytes according to your needs.
    Do you use Modbus?
    in reply to: String tag communication in rapid scada #946
    About Silverlight:
    Does the following page works in your IE and Firefox?
    https://www.microsoft.com/silverlight/skinning-and-styling/demo/
    Also try to open Rapid SCADA in Firefox. Does it work in Firefox?
    in reply to: String tag communication in rapid scada #945
    How to communicate the string elements in rapid scada , please send the document for configuration.
    Please provide more details in a separate topic. What are you going to implement?
    One issue – one topic.
    in reply to: Unable to send emails #941
    Of course you can use DNS.
    E.g.,
    smtp.gmail.com, port 587
    in reply to: Unable to send emails #939
    Functionality of sending emails will be added to the default configuration.
    in reply to: Unable to send emails #936
    You right, the documentation should be improved.
    The description that you found in the source is shown on Device Libraries tab of Communicator application.
    To send emails automatically you need to install and configure Automatic Control Module
    Are emails sent successfully for now?
    in reply to: Graph #933
    The new web service allows quickly get trial key http://trial.rapidscada.net/
    in reply to: Graph #932
    Send me the comuter code by email, and I’ll send you trial keys.
    Does that mean, if my Computer crashes and I have to Setup the System new, I have to buy new licenses?
    In general, yes. But if you try to set the same network configuration that exists before crash, there is a chance to use the same key.
