Viewing 15 posts - 5,461 through 5,475 (of 6,388 total)
  • in reply to: Chartpro request: independent scales #2316
    Nope. We are looking for a sponsor for this function ))
    You can try Dashboard plugin and place one chart below another. See the demo
    in reply to: About trial keys #2315
    I checked the log of the trial service. The emails was successfully sent to E***g@outlook.com
    If you didn’t receive them, check Spam folder or try using another email address. If recommendations don’t help, send your codes to our email info@…
    in reply to: Send IEEE Float To device #2309
    To covert a value entered manually into a command value you definitely need a formula. Because command value is a double (8 bytes), but you need to send only a single (4 bytes).
    in reply to: Send IEEE Float To device #2308
    roska, I tried to reproduce the problem.
    1. I added command into Modbus template: Holding Registers, Multiple, 2 elements
    2. Using Communicator GUI I sent a binary command in hex format: 429BC28F
    3. Data were sent:
    Send (17): 00 00 00 00 00 0B 01 10 00 64 00 02 04 42 9B C2 8F
    Registers value are: 0x429B (17051), 0xC28F (49807) according to http://modbus.rapidscada.net/
    Do you get another results if repeat the above sequence?
    (I use Modbus TCP, it doesn’t matter)
    in reply to: Problem in Sending Modbus (Command) Float32 data #2296
    You should use SetVal or SetData according to http://doc.rapidscada.net/content/en/software-configuration/using-formulas.html
    There is no function named CnlValSet unless you define it by yourself.
    in reply to: Server is unavailable #2295
    The cause is:
    2017-06-27 15:44:05 Error compiling the source code of the formulas:
    Line 85, column 31: error CS0589: Internal compiler error during parsingSystem.FormatException: Input string was not in the correct format
    Line 0, column 0: error : at System.Double.Parse
    You have to switch localization of RPi into English and restart SCADA-Server. There is a bug in Mono .NET compiler.
    in reply to: Scheme Editor Beta #2292
    The Editor is now included in Rapid SCADA 5.2.0
    in reply to: Problem in Sending Modbus (Command) Float32 data #2290
    If you need to send 2 commands one by one, you can do it with Automatic Control Module. In this case, an operator sends one command via UI, then the module reacts on it and sends two commands.
    in reply to: How to control GPIO for raspberry? #2289
    Thanks a lot!
    A also recommend to post the above links with a description of a work to RPi forum, like this.
    in reply to: Problem in Sending Modbus (Command) Float32 data #2288
    A command value doesn’t stored somewhere in SCADA. It is just sent to PLC. I’m not really understand the task of changing a command from 1 to 0.
    You can change a value of an input channel programmatically.
    • This reply was modified 9 years, 3 months ago by Mikhail.
    in reply to: Problem in Sending Modbus (Command) Float32 data #2281
    Please explain the task
    in reply to: Communication errors #2280
    I just sent you an email.
    in reply to: Communication errors #2278
    Hi Marek,
    info… is the correct email, but I haven’t receive a message from you. Can you send it again, please. Usually I reply within a day.
    in reply to: Install exe. file Rapid Scada on Raspberry PI 3 #2276
    According to my experience with Win 10 IoT, it is impossible to install usual release of Rapid SCADA to this OS. The cause is that Win 10 IoT has no “normal” .NET. The applications must be written as Windows Universal Application. More over, and the biggest problem that Win 10 IoT doesn’t include web server to deploy the web app of Rapid SCADA.
    May be something changes after I experimented with Win 10 IoT. It would be great, if you share you experience.
    in reply to: Problem in Sending Modbus (Command) Float32 data #2272
    You can also use BitConverter.GetBytes as a formula of an output channel to convert a number into array of bytes:
    BitConverter.GetBytes((float)Cmd)
