Viewing 15 posts - 5,116 through 5,130 (of 6,389 total)
  • in reply to: Intergration data input into cloud system #3232
    Hi Hakim,
    Please provide correct links.
    in reply to: Error updating the hourly data #3231
    The link is related to your Google drive. I can’t open it. You should text here a link of the shared file.
    in reply to: Scheme editor opening in webpage #3230
    The new version of the editor opens a web page. It’s OK.
    in reply to: SQL Export Issues #3222
    SQL executes when data are coming from Communicator, but SCADA-Server saves all data to a disk periodically at the same moment. Value can change several times before saving to a disk.
    in reply to: Scheme editor (problems) windows 10 #3221
    Please try the following:
    Copy the link from the address bar and paste it into Chrome. Does it work? If not, press F12 and copy messages from the Console tab.
    in reply to: arduino #3216
    Likely. Depends on the sketch you upload to it.
    in reply to: Intergration data input into cloud system #3214
    Cloud system is an abstract term. You can build your system based on Rapid SCADA or use other software and integrate it with Rapid SCADA. First of all, you should choose the architecture of the system.
    in reply to: Scheme editor (problems) windows 10 #3212
    The web browser have to be opened to show a scheme. What happened when you click “Earth” button?
    The Editor shown in the video is outdated.
    in reply to: arduino #3211
    If your Arduino supports Modbus, it can be connected to Rapid SCADA. See the boards here https://www.arduino.cc/ They are all good
    in reply to: Observer pattern #3207
    It would be great. Please notify me about results.
    I suppose, you should create a module for SCADA-Server that provides API with such pattern. Also you could use OPC UA for this purpose. The module should be OPC UA server and your app is OPC UA client.
    in reply to: Sending PC time to peripheral device #3206
    OK 🙂
    in reply to: Email sender bug #3205
    For gmail you should “Enable IMAP” on “Forwarding and POP/IMAP” settings.
    in reply to: Scheme editor (problems) windows 10 #3204
    Please make a screenshot of the issue and provide link to it here. Also check C:\SCADA\ScadaSchemeEditor\Log\ScadaSchemeEditor.log for additional info.
    in reply to: Sending PC time to peripheral device #3192
    Yes. You need:
    – Automatic Control module
    – Input channel with a formula that changes its value every 60 seconds. This is a trigger for sending command.
    – Output channel that automatically calculates command value.
    in reply to: Email sender bug #3191
    Both examples work on my workstation. What mail server do you use for sending (in the “device” properties)? I use gmail.
