Viewing 15 posts - 4,996 through 5,010 (of 6,391 total)
  • in reply to: ModDBExport to Oracle #3536
    ScadaServer generated current data with the millisecond of timestamp are all zero.
    What version of MySQL do you use?
    in reply to: ModDBExport to Oracle #3535
    Thank you for the solution. I suppose, that the wrong statement is in the queue and never can be skipped.
    in reply to: ModDBExport #3534
    Do you have an idea in which case a sent value is changed to 0, and in which case it is saved correctly?
    in reply to: Source Code KpOpc.dll #3533
    for the command, you can only make boolean command on/off ?
    Command of the Standard type has a value of double type.
    Binary command allows sending any data.
    in reply to: Modbus Slave mode #3532
    Rapid SCADA works as Modbus master, and it can be TCP server or TCP slave.
    I still can’t open tcp connection with Local tcp port 502, error:The network connection was refused by the server.
    You can use this Hercules utility to test connection.
    in reply to: Distinct ports on the same device #3531
    communication line for each port
    If I were you, I did this way.
    Also possible create a one command line and specify ports for each device in the Call Number field.
    in reply to: Installation has completed with errors #3530
    Please make screenshots of the following folders
    C:\SCADA\ScadaComm
    C:\SCADA\ScadaServer
    and paste links to them here.
    If the folders are not empty, execute svc_install.bat from command line as administrator. Make screenshots of the output.
    in reply to: ModDBExport to Oracle #3519
    It seems like server executes requests too long. Can you stop the Communicator service and send current data using Server’s Generator?
    How many record already contained in the table cnldata ?
    in reply to: ModDBExport #3518
    OK, write here to continue the topic.
    in reply to: Source Code KpOpc.dll #3517
    Of course, sorry ))
    Would you create a release of your driver on GitHub to allow others to easily use the driver?
    in reply to: Modbus Slave mode #3516
    Hi catcute,
    Could you explain the idea what you are going to implement?
    Even if you switch operating mode to Slave, the existing Modbus driver works as master. Slave means that Communicator waits for incoming connection, TCP slave (TCP server) not Modbus slave.
    in reply to: Source Code KpOpc.dll #3502
    How do you integrate node-opcua with .NET?
    in reply to: ModDBExport to Oracle #3501
    Please find the *.log file of the module in SCADA\ScadaServer\Log\ and check the errors in this file.
    in reply to: arduino #3500
    Thank you!
    Does it work with Arduino Nano and Uno?
    in reply to: ModDBExport #3491
    When we modify Communicator the next time, likely we will create the necessary options. If you need this changes in time, we could talk about purchasing the development.
