Viewing 15 posts - 3,061 through 3,075 (of 6,392 total)
  • in reply to: SCADA V6 #9101
    Very interesting.
    Please keep the community informed about new developments.
    Note that driver and module interfaces may change during the development of v6.
    in reply to: SCADA V6 #9098
    I will do some work on the web
    What do you plan to do?
    in reply to: SCADA V6 #9095
    Don’t use classic Windows services from v6. Run *App.exe that work on .NET5.
    in reply to: SCADA V6 #9094
    Uploading project function doesn’t work for now. Use these utilities to convert configuration database from XML to new DAT format.
    in reply to: Grafana (backend) and Rapid SCADA #9093
    On Linux, open terminal and try that command.
    in reply to: ChartPro export data in hourly #9088
    SheetOptions specifies the input parameters for the report. To setup report view, you should configure the report sections. For further questions about Elastic Report, please start a new appropriate topic.
    in reply to: SCADA V6 #9087
    Everything is on GitHub.
    in reply to: Function SendStandardCommand #9080
    It is sent successfully if the both, returned value and result are true.
    in reply to: EncodeAscii #9079
    You should add strings into a unit table. See “Off-On” for example. String conversion is not needed.
    in reply to: ChartPro export data in hourly #9078
    This is planned for the future.
    in reply to: ChartPro export data in hourly #9073
    Fully agree with @manjey73
    in reply to: event triger #9072
    Likely, you should not set the channel 2570 from itself.
    The formula of the channel 2570 should be: Val(2510) > 0 ? Val(2526) : Val()
    in reply to: EncodeAscii #9071
    Please explain why do you need it? May be we can find the better solution.
    in reply to: Unable to write OPC Value #9063
    Thanks for the info. If possible, move from classic OPC to OPC UA.
    The good thing is that in v6 there are only 2 types of input channels: measured and calculated.
